Ignition Fortress multi camera plugin
Hi all,
I'm creating a multicamera plugin and I would like to understand what is the correct way to retrieve the images from the sensors declared in the SDF.
I successfully created my sdf::Camera objects in the Configure function by using EntitiesByComponents, but now I can't understand how to correctly create the ignition::sensors::CameraSensor objects to be used to extract the frames in the PostUpdate function.
Thank you Walter
Asked by Myzhar on 2022-07-06 08:47:13 UTC
