Gazebo Robot Move Selfs
I maked r2000ic125l Gazebo robot
this robot start move self in gazebo and link1 link3 and link6 is can not move from rqtjointtrajectorycontroller (link2 link4 and link5 is works correctly)
I believe the cause is friction and effort. Or is there another cause?
this is URDF Please Hepl me Thank you
<!-- Used for fixing robot to Gazebo 'base_link' -->
<link name="world"/>
<joint name="base_link_to_world_joint" type="fixed">
<parent link="world"/>
<child link="${prefix}base_link"/>
<!-- links: main serial chain -->
<link name="${prefix}base_link">
<origin rpy="0 0 0" xyz="0 0 0"/>
<mass value="0.388"/>
<inertia ixx="0.1" ixy="0" ixz="0"
iyy="0.1" iyz="0"
izz="0.1"/>
<visual>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/visual/base_link.stl" />
<xacro:material_fanuc_gray40 />
<collision>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/collision/base_link.stl" />
<link name="${prefix}link_1">
<mass value="0.253"/>
<inertia ixx="0.001" ixy="0" ixz="0"
iyy="0.001" iyz="0"
izz="0.001"/>
<visual>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/visual/link_1.stl" />
<xacro:material_fanuc_yellow />
<collision>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/collision/link_1.stl" />
<link name="${prefix}link_2">
<mass value="0.136"/>
iyy="0.1" iyz="0"
izz="0.1"/>
<visual>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/visual/link_2.stl" />
<collision>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/collision/link_2.stl" />
<link name="${prefix}link_3">
<mass value="0.321"/>
iyy="0.1" iyz="0"
izz="0.1"/>
<visual>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/visual/link_3.stl" />
<collision>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/collision/link_3.stl" />
<link name="${prefix}link_4">
<mass value="0.222"/>
<inertia ixx="0.01" ixy="0" ixz="0"
iyy="0.01" iyz="0"
izz="0.01"/>
<visual>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/visual/link_4.stl" />
<collision>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/collision/link_4.stl" />
<link name="${prefix}link_5">
<mass value="0.207"/>
iyy="0.1" iyz="0"
izz="0.1"/>
<visual>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/visual/link_5.stl" />
<collision>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/collision/link_5.stl" />
<link name="${prefix}link_6">
<mass value="0.14"/>
iyy="0.1" iyz="0"
izz="0.1"/>
<visual>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/visual/link_6.stl" />
<collision>
<mesh filename="package://r2000ic125l_description/meshes/r2000ic125l/collision/link_6.stl" />
<!-- joints: main serial chain -->
<joint name="${prefix}joint_1" type="revolute">
<origin xyz="0 0 0.670" rpy="0 0 0"/>
<parent link="${prefix}base_link"/>
<child link="${prefix}link_1"/>
<axis xyz="0 0 1"/>
<limit lower="${radians(-185)}" upper="${radians(185)}" effort="10.0" velocity="${radians(130)}" />
<dynamics damping="50" friction="10"/>
<joint name="${prefix}joint_2" type="revolute">
<origin xyz="0.312 0 0" rpy="0 0 0"/>
<parent link="${prefix}link_1"/>
<child link="${prefix}link_2"/>
<axis xyz="0 1 0"/>
<limit lower="${radians(-60)}" upper="${radians(76)}" effort="10.0" velocity="${radians(115)}" />
<dynamics damping="50" friction="1"/>
<joint name="${prefix}joint_3" type="revolute">
<origin xyz="0 0 1.075" rpy="0 0 0"/>
<parent link="${prefix}link_2"/>
<child link="${prefix}link_3"/>
<axis xyz="0 -1 0"/>
<limit lower="${radians(-121)}" upper="${radians(180)}" effort="4.0" velocity="${radians(125)}" />
<joint name="${prefix}joint_4" type="revolute">
<origin xyz="0 0 0.225" rpy="0 0 0"/>
<parent link="${prefix}link_3"/>
<child link="${prefix}link_4"/>
<axis xyz="-1 0 0"/>
<limit lower="${radians(-360)}" upper="${radians(360)}" effort="10.0" velocity="${radians(180)}" />
<dynamics damping="50" friction="0.1"/>
<joint name="${prefix}joint_5" type="revolute">
<origin xyz="1.730 0 0" rpy="0 0 0"/>
<parent link="${prefix}link_4"/>
<child link="${prefix}link_5"/>
<limit lower="${radians(-125)}" upper="${radians(125)}" effort="4.0" velocity="${radians(180)}" />
<joint name="${prefix}joint_6" type="revolute">
<origin xyz="0.215 0 0" rpy="0 0 0"/>
<parent link="${prefix}link_5"/>
<child link="${prefix}link_6"/>
<limit lower="${radians(-360)}" upper="${radians(360)}" effort="4.0" velocity="${radians(260)}" />
<!-- For gazebo simulation -->
<transmission name="${prefix}joint_1_trans">
<provideFeedback>true</provideFeedback>
<implicitSpringDamper>0</implicitSpringDamper>
<motorTorqueConstant>0.418</motorTorqueConstant>
<joint name="${prefix}joint_1">
<hardwareInterface>hardware_interface/PositionJointInterface</hardwareInterface>
<actuator name="${prefix}joint_1_motor">
</actuator>
</transmission>
<transmission name="${prefix}joint_2_trans">
<motorTorqueConstant>140.418</motorTorqueConstant>
<joint name="${prefix}joint_2">
<actuator name="${prefix}joint_2_motor">
</actuator>
</transmission>
<transmission name="${prefix}joint_3_trans">
<joint name="${prefix}joint_3">
<actuator name="${prefix}joint_3_motor">
</actuator>
</transmission>
<transmission name="${prefix}joint_4_trans">
<joint name="${prefix}joint_4">
<actuator name="${prefix}joint_4_motor">
</actuator>
</transmission>
<transmission name="${prefix}joint_5_trans">
<joint name="${prefix}joint_5">
<actuator name="${prefix}joint_5_motor">
</actuator>
</transmission>
<transmission name="${prefix}joint_6_trans">
<joint name="${prefix}joint_6">
<actuator name="${prefix}joint_6_motor">
</actuator>
</transmission>
<gazebo>
<plugin name='gazebo_ros_control' filename='libgazebo_ros_control.so'>
<robotNamespace>/r2000ic125l</robotNamespace>
<legacyModeNS>false</legacyModeNS>
<gazebo reference="${prefix}base_link">
<material>Gazebo/Gray</material>
<selfCollide>False</selfCollide>
<implicitSpringDamper>True</implicitSpringDamper>
<gazebo reference="${prefix}link_1">
<material>Gazebo/Yellow</material>
<gazebo reference="${prefix}link_2">
<gazebo reference="${prefix}link_3">
<gazebo reference="${prefix}link_4">
<gazebo reference="${prefix}link_5">
<gazebo reference="${prefix}link_6">
Asked by m-robot on 2022-07-28 19:37:12 UTC
