[Ignition] PostRender event not called
asked 2022-08-02 08:31:21 -0500
Myzhar gravatar image
Hi all, I have a problem when integrating a camera plugin that I designed in ROS. If I use the plugin in a world created with an SDF it correctly works, but if I attach it to a camera declared in a URDF to be used in ROS, the PostRender event (ignition::gazebo::events::PostRender) is never called and I cannot understand why. The plugin is correctly loaded, the Configure and PostUpdate callbacks are correctly called.
Any idea?
Thank you Walter
answered 2022-08-04 01:29:09 -0500
The problem was the missing MinimalScene plugin. When I added it and correctly set all the environment paths everything started to work as expected.
Asked: 2022-08-02 08:31:21 -0500
Seen: 48 times
Last updated: Aug 04 '22
