My robot cannot be displayed properly in the gazebo
Hello, I want to add RG2 gripper to ABB irb1200 robot and do some tests in Gazebo environment. I created a package from my URDF file using Moveit Setup Assistant. After making some changes like turning off the gravity and adding inertia data to make it work in Gazebo, I tried to run it. However, I couldn't get it to look properly in the Gazebo. There is no problem when I view it from Rviz. What could be the problem? I'm new to ROS and Gazebo.
I'm working with ROS Kinetic and Gazebo 7.
It also gives the error below when I run the launch file. I don't know if it is relevant.
Here is the gazebo screen.
Here is the Rviz screen.
And here is the URDF file.
<?xml version="1.0" ?>
<mass value="13.7742"/>
<origin xyz="-0.028986 0.000596 0.11273"/>
<inertia ixx="0.101998" ixy="0.000495482" ixz="0.000311158" iyy="0.13969" iyz="-0.000245375" izz="0.130433"/>
<mesh filename="file:/root/catkin_ws/irb1200/visual/base_link.dae" />
<material name="yellow">
<color rgba="1 1 0 1" />
<mesh filename="file:/root/catkin_ws/irb1200/collision/base_link.stl" />
<link name="link_1">
<mass value="11.8419"/>
<origin xyz="0.000877 -0.000631 -0.062883"/>
<inertia ixx="0.11194" ixy="-4.54988e-05" ixz="0.000280961" iyy="0.0915159" iyz="-0.000109905" izz="0.0876456"/>
<mesh filename="file:/root/catkin_ws/irb1200/visual/link_1.dae" />
<material name="yellow" />
<mesh filename="file:/root/catkin_ws/irb1200/collision/link_1.stl" />
<link name="link_2">
<mass value="17.5394"/>
<origin xyz="-0.000928 -0.000497 0.250051"/>
<inertia ixx="0.493558" ixy="1.32136e-05" ixz="0.000209024" iyy="0.462939" iyz="-0.00179901" izz="0.0894214"/>
<mesh filename="file:/root/catkin_ws/irb1200/visual/link_2.dae" />
<mesh filename="file:/root/catkin_ws/irb1200/collision/link_2.stl" />
<link name="link_3">
<mass value="7.46365"/>
<origin xyz="0.099588 0.001143 0.032333"/>
<inertia ixx="0.0252424" ixy="0.000142737" ixz="-0.00565542" iyy="0.0906438" iyz="0.000142213" izz="0.0825079"/>
<mesh filename="file:/root/catkin_ws/irb1200/visual/link_3.dae" />
<mesh filename="file:/root/catkin_ws/irb1200/collision/link_3.stl" />
<link name="link_4">
<mass value="2.74436"/>
<origin xyz="0.381678 0.001261 0.005168"/>
<inertia ixx="0.00573099" ixy="-0.000131119" ixz="0.000380232" iyy="0.0118352" iyz="-2.26565e-05" izz="0.0114428"/>
<mesh filename="file:/root/catkin_ws/irb1200/visual/link_4.dae" />
<mesh filename="file:/root/catkin_ws/irb1200/collision/link_4.stl" />
<link name="link_5">
<mass value="0.62953"/>
<origin xyz="0.011197 -0.001056 0.000109"/>
<inertia ixx="0.000502815" ixy="-1.03173e-05" ixz="-8.74347e-08" iyy="0.00108856" iyz="2.07657e-07" izz="0.000918873"/>
<mesh filename="file:/root/catkin_ws/irb1200/visual/link_5.dae" />
<mesh filename="file:/root/catkin_ws/irb1200/collision/link_5.stl" />
<link name="link_6">
<mass value="0.137"/>
<origin xyz="-0.00706 -0.00017 -1.32E-06" rpy="0 0 0"/>
<inertia ixx="0.001" ixy="0" ixz="0" iyy="0.001" iyz="0" izz="0.001"/>
<mesh filename="file:/root/catkin_ws/irb1200/visual/link_6.dae" />
<mesh filename="file:/root/catkin_ws/irb1200/collision/link_6.stl" />
<!-- end of link list -->
<!-- Hand Links -->
<!-- joint list -->
<link name="rg2_hand">
<mass value="0.2" />
<inertia ixx="0.001" ixy="0" ixz="0" iyy="0.001" iyz="0" izz="0.001" />
<visual name="rg2_hand_visual">
<mesh filename="file:/root/catkin_w/visual/rg2/hand.dae" />
<link name="rg2_leftfinger">
<mass value="0.1" />
<visual>
<mesh filename="file:/root/catkin_w/visual/rg2/finger.dae" />
<collision>
<mesh filename="file:/root/catkin_w/collision/rg2/finger.dae" />
<link name="rg2_rightfinger">
<visual>
<origin rpy="3.141592653589793 0 0" xyz="0 0 0" />
<collision>
<joint name="ur5_hand_joint" type="fixed">
<parent link="link_6" />
<child link="rg2_hand" />
<limit lower="0" upper="0" effort="0" velocity="0" />
<dynamics damping="1.0" friction="0.1" />
<!-- Hand Links -->
<!-- joint list -->
<joint name="joint_1" type="revolute">
<origin rpy="0 0 0" xyz="0 0 0.3991" />
<axis xyz="0 0 1" />
<parent link="base_link" />
<child link="link_1" />
<limit effort="1000" lower="-2.967" upper="2.967" velocity="5.027" />
<dynamics damping="50.0" friction="1" />
<joint name="joint_2" type="revolute">
<origin rpy="0 0 0" xyz="0 0 0" />
<axis xyz="0 1 0" />
<parent link="link_1" />
<child link="link_2" />
<limit effort="1000" lower="-1.745" upper="2.269" velocity="4.189" />
<dynamics damping="50" friction="1" />
<joint name="joint_3" type="revolute">
<origin rpy="0 0 0" xyz="0 0 0.448" />
<parent link="link_2" />
<child link="link_3" />
<limit effort="1000" lower="-3.491" upper="1.222" velocity="5.236" />
<dynamics damping="10" friction="1" />
<joint name="joint_4" type="revolute">
<origin rpy="0 0 0" xyz="0 0 0.042" />
<axis xyz="1 0 0" />
<parent link="link_3" />
<child link="link_4" />
<limit effort="1000" lower="-4.712" upper="4.712" velocity="6.981" />
<dynamics damping="5.0" friction="1" />
<joint name="joint_5" type="revolute">
<origin rpy="0 0 0" xyz="0.451 0 0 " />
<parent link="link_4" />
<child link="link_5" />
<limit effort="1000" lower="-2.269" upper="2.269" velocity="7.069" />
<dynamics damping="2.0" friction="1" />
<joint name="joint_6" type="revolute">
<origin rpy="0 0 0" xyz="0.082 0 0 " />
<parent link="link_5" />
<child link="link_6" />
<limit effort="1000" lower="-6.283" upper="6.283" velocity="10.472" />
<dynamics damping="1.0" friction="1" />
<joint name="joint_6-tool0" type="fixed">
<child link="tool0" />
<origin rpy="0 1.57079632679 0" xyz="0 0 0" />
<!-- end of joint list -->
<!-- ROS base_link to ABB World Coordinates transform -->
<link name="world" />
<joint name="world_to_base_link_joint" type="fixed">
<parent link="world" />
<child link="base_link" />
<link name="base" />
<joint name="base_link-base" type="fixed">
<child link="base" />
<!-- Finger Joints -->
<joint name="rg2_finger_joint1" type="revolute">
<parent link="rg2_hand" />
<child link="rg2_leftfinger" />
<origin rpy="0 0 0" xyz="0.105 0.017 0" />
<limit effort="10.6" lower="0.0" upper="1.18" velocity="1.57" />
<joint name="rg2_finger_joint2" type="revolute">
<child link="rg2_rightfinger" />
<origin rpy="0 0 0" xyz="0.105 -0.017 0" />
<axis xyz="0 0 -1" />
<!-- End-effector -->
<link name="tool0" />
<joint name="end_effector_frame_fixed_joint" type="fixed">
<origin xyz="0 0.275 0" rpy="-1.570796325 0 0" />
<dynamics damping="10" friction="1.0"/>
<transmission name="trans_joint_1">
<joint name="joint_1">
<actuator name="joint_1_motor">
</actuator>
</transmission>
<transmission name="trans_joint_2">
<joint name="joint_2">
<actuator name="joint_2_motor">
</actuator>
</transmission>
<transmission name="trans_joint_3">
<joint name="joint_3">
<actuator name="joint_3_motor">
</actuator>
</transmission>
<transmission name="trans_joint_4">
<joint name="joint_4">
<actuator name="joint_4_motor">
</actuator>
</transmission>
<transmission name="trans_joint_5">
<joint name="joint_5">
<actuator name="joint_5_motor">
</actuator>
</transmission>
<transmission name="trans_joint_6">
<joint name="joint_6">
<actuator name="joint_6_motor">
</actuator>
</transmission>
<transmission name="trans_rg2_finger_joint1">
<joint name="rg2_finger_joint1">
<actuator name="rg2_finger_joint1_motor">
</actuator>
</transmission>
<transmission name="trans_rg2_finger_joint2">
<joint name="rg2_finger_joint2">
<actuator name="rg2_finger_joint2_motor">
</actuator>
</transmission>
<selfCollide>true</selfCollide>
<gazebo reference="link_1">
<gazebo reference="link_2">
<gazebo reference="link_3">
<gazebo reference="link_4">
<gazebo reference="link_5">
<gazebo reference="link_6">
<gazebo reference="rg2_hand">
<gazebo reference="rg2_leftfinger">
<gazebo reference="rg2_rightfinger">
<gazebo reference="tool0">
<gazebo>
Asked by erenguldal on 2022-08-12 04:24:31 UTC
