Texture model from URDF
Gazebo Version: Fortress
ROS Version: Humble
I am working on testing out an extrinsic camera calibration library and I would like to use Gazebo as my ground truth but I need to attach a calibration grid to the end of my robot arm and I'm struggling to get it to render properly in simulation.
In my URDF I have the following (see below) and you can see that I have tried several different methods (they are commented out) but the only way I have been able to change the material of this link is with the
<material name="">
<color rgba="1.0 0 0 1" />
tag which is not super useful because its a single color (I need to map an image to the surface).
Inside the <gazebo reference= block I have tried with and without the <visual name="visual"> blocks and when I don't include them I get the following message when I start the simulation.
[ign gazebo-4] Warning [parser_urdf.cc:1184] Attribute value string not set
If anyone has suggestions or tips on how I can get this working I would really appreciate your help!
<link name="cal_grid_link">
<mass value="0.1" />
<inertia ixx="0.00021268" ixy="5.21E-06" ixz="2.91E-06" iyy="0.00106371" iyz="1.1E-07" izz="0.00108465" />
<box size="0.1 0.2 0.01"/>
<!-- <material name="green"> Does NOT work!!!
<ambient>1 1 1 1</ambient>
<diffuse>0 1 0 1</diffuse>
<specular>0 0 0.3 1</specular>
</material> -->
<material name="">
<gazebo reference="cal_grid_link">
<!-- <visual name="visual"> Does NOT work!!!
<script>
<name>Gazebo/Red</name>
</script>
</visual> -->
<!-- <visual> Does NOT work!!!
<material name="cal_pattern">
<diffuse>1 1 1 1</diffuse>
<specular>0.4 0.4 0.4 1</specular>
<pbr>
<metal>
<albedo_map>file:///root/calibration_ws/src/ros2_kortex/kortex_description/arms/gen3_lite/6dof/meshes/materials/textures/pattern.png</albedo_map>
</metal>
</pbr>
</visual> -->
<joint name="cal_grid_joint" type="fixed">
<origin xyz="0.3 0.3 0.3" rpy="0 0 0" />
<parent link="${prefix}upper_wrist_link" />
<child link="cal_grid_link" />
Asked by MarqRazz on 2022-09-01 13:09:54 UTC
I've run out of ideas here, if there are any Gazebo experts out there I could really use your help!
I tried to embed the texture into the mesh with Blender and it works in Rviz but not in Ignition Gazebo.
Asked by MarqRazz on 2022-09-06 13:29:37 UTC
@MarqRazz Did you find a solution ? I'm facing the same issue it works in rviz but not in gazebo...
Asked by Clement on 2022-10-11 08:04:34 UTC
