Ignition Fortress: Parsing top-level models with bounding box from within a global world sensor plugin
we are currently implementing a global world sensor plugin in Ignition Fortress. This plugin collects different information from the current scene (wrt. models) and converts them to an ignition::ModelV message. Later on, we are using the rosbridge to convert the ignition::ModelV messages to a own ROS message definition.
The model shall parse the scene graph wrt.
- identifier
- name
- pose
- bounding box of each model.
Therefore our implementation mainly takes place in the PoseUpdate step of the simulation:
void ObstacleWorldSensorPlugin::PostUpdate(const ignition::gazebo::UpdateInfo& _info,
const ignition::gazebo::EntityComponentManager& _ecm)
if (_info.paused) return;
// prepare variable to be filled with the objects/models inside simulation.
ignition::msgs::Model_V model_vector_msg;
// fill header, especially time stamp by sim_time
ignition::msgs::Time* timestamp = model_vector_msg.mutable_header()->mutable_stamp();
timestamp->CopyFrom(ignition::gazebo::convert<ignition::msgs::Time>(_info.simTime));
_ecm.Each<ignition::gazebo::components::Model, ignition::gazebo::components::Name, ignition::gazebo::components::Pose>( [&](const ignition::gazebo::Entity& _entity, const ignition::gazebo::components::Model* _model, const ignition::gazebo::components::Name* _nameComp, const ignition::gazebo::components::Pose* _poseComp) -> bool
ignmsg << "Handling current entity [" << _entity << "]: " << _nameComp->Data() << " of scene graph." << std::endl;
// issue #1: Filter or manipulate iteration, so that only top-level models are iterated...
// prepare variable for the model
// fill header and pose with position and orientation of model
ignition::msgs::Model* model_msg = model_vector_msg.add_models();
ignition::msgs::Header* header = model_msg->mutable_header();
ignition::msgs::Pose* pose_msg = model_msg->mutable_pose();
ignition::msgs::Vector3d* position_msg = pose_msg->mutable_position();
// fill message content
model_msg->set_name(_nameComp->Data());
model_msg->set_id(_entity);
ignition::msgs::Set(pose_msg, _poseComp->Data());
// issue #2: get bounding box of model
return true;
this->dataPtr->model_pub.publish(model_vector_msg);
Currently, we are facing the following issues:
- Firstly, we only want to detect the top-level model (in the case of nested models).
- Secondly, we want to parse the bounding box (geometric extensions) of the model inside the scene graph
Any help is appreciated.
BR.
Asked by Illuminatur on 2022-09-03 09:11:54 UTC
