Spawn object attached to a frame in simulation
ROS Version: Humble
Gazebo Version: Fortress
I'm looking for suggested ways of spawning an object that is attached to a robot arm at run time. That is I'm spawning a URDF model of the arm at startup and then I want to spawn and attach an object to an arm link while running the simulation.
If I use the service interface with the following command:
ign service -s /world/depot/create --reqtype ignition.msgs.EntityFactory --reptype ignition.msgs.Boolean --timeout 1000 --req 'sdf_filename: "/root/calibration_ws/cal_grid/model.sdf", name: "sdf_model"'
And here is my sdf defined model and joint to attach it to the robot:
<model name="charuco_default">
<link name="charuco_link">
<mass>1.0</mass>
<joint name="cal_joint" type="fixed">
<parent>upper_wrist_link</parent>
<child>charuco_link</child>
<pose>0 0 2 0 0 0</pose>
But when I spawn the object it is not attached to my robots link and appears at world 0,0,0
When I look in the UI I can see that the model sdf_model (which is the name I spawned with) lists the Parent Entry as 1 which is the same for my robot which I assume means world is the parent.
If I run: ign model -m sdf_model I get.
Model: [66]
- Name: sdf_model
- Pose [ XYZ (m) ] [ RPY (rad) ]:
[-0.000000 0.000000 -0.004950]
[0.000001 0.000001 0.000065]
- Link [67]
- Name: charuco_link
- Parent: sdf_model [66]
- Mass (kg): 1.000000
- Inertial Pose [ XYZ (m) ] [ RPY (rad) ]:
[0.000000 0.000000 0.000000]
[0.000000 -0.000000 0.000000]
- Inertial Matrix (kg.m^2):
[1.000000 0.000000 0.000000]
[0.000000 1.000000 0.000000]
[0.000000 0.000000 1.000000]
Any ideas to make it work as desired?
More testing...
So I tried to set my model name of my sdf to the robot's name but get a bunch of errors looking it up.
[ign gazebo-4] [Err] [UserCommands.cc:1194] Error Code 19: Msg: Child frame with name[charuco_default] specified by joint with name[cal_joint] not found in model with name[kinova].
[ign gazebo-4] [Err] [UserCommands.cc:1194] Error Code 24: Msg: FrameAttachedToGraph error, Non-LINK vertex with name [kinova::cal_joint] is disconnected; it should have 1 outgoing edge in MODEL attached_to graph.
[ign gazebo-4] [Err] [UserCommands.cc:1194] Error Code 24: Msg: Graph has __model__ scope but sink vertex named [kinova::cal_joint] does not have FrameType LINK or STATIC_MODEL when starting from vertex with name [kinova::cal_joint].
[ign gazebo-4] [Err] [UserCommands.cc:1194] Error Code 25: Msg: relative_to name[charuco_default] specified by joint with name[cal_joint] does not match a nested model, link, joint, or frame name in model with name[kinova].
[ign gazebo-4] [Err] [UserCommands.cc:1194] Error Code 27: Msg: PoseRelativeToGraph error, Vertex with name [kinova::cal_joint] is disconnected; it should have 1 incoming edge in MODEL relative_to graph.
[ign gazebo-4] [Err] [UserCommands.cc:1194] Error Code 27: Msg: PoseRelativeToGraph unable to find path to source vertex when starting from vertex with id [4].
[ign gazebo-4] [Err] [UserCommands.cc:1194] Error Code 20: Msg: parent frame with name[upper_wrist_link] specified by joint with name[cal_joint] not found in model with name[kinova].
[ign gazebo-4] [Err] [UserCommands.cc:1194] Error Code 19: Msg: child frame with name[charuco_default] specified by joint with name[cal_joint] not found in model with name[kinova].
[ign gazebo-4] [Err] [UserCommands.cc:1194] Error Code 22: Msg: FrameAttachedToGraph unable to find unique frame with name [charuco_default] in graph.
[ign gazebo-4] [Err] [UserCommands.cc:1194] Error Code 22: Msg: FrameAttachedToGraph unable to find unique frame with name [upper_wrist_link] in graph.
[ign gazebo-4] [Err] [UserCommands.cc:1194] Error Code 21: Msg: joint with name[cal_joint] in model with name[kinova] specified parent frame [upper_wrist_link] and child frame [charuco_default] that both resolve to [], but they should resolve to different values.
Asked by MarqRazz on 2022-09-06 21:24:22 UTC
SDFormat models have to be self contained, i.e, a joint cannot reference a link/frame outside of the model (except world). So when you tried to spawn your model, it's failing at the SDFormat parsing stage.
This kind of thing is best accomplished using a plugin. My suggestion is to try using the DetachableJoint plugin. You can put the plugin in the object you're spawning at runtime. By default, the DetachableJoint plugin creates a fixed joint between two links when it gets loaded.
Asked by azeey on 2022-09-28 13:40:53 UTC
