How do i start gazebo form a launch file with dart physics engine?
Hi everyone!
I am trying to use gazebo with dart from a launch file.
My problem is that i get the following error:
[ERROR] [1662735927.747255354]: ROS get_physics_properties service call does not yet support physics engine [dart].
and this warning
Warning [BodyNode.cpp:469] [BodyNode] A negative or zero mass [0] is set to BodyNode [link], which can cause invalid physical behavior or segfault. Consider setting positive value instead.
I wonder if i am setting the physics engine correctly, i do this in my launch file as such:
<!-- Launch gazebo with an empty world -->
    <arg name="physics" value="dart" />
    <arg name="world_name" value="$(find microrobot)/worlds/custom_empty.world"/>
    <arg name="paused" default="true" />
    <arg name="use_sim_time" default="true" />
    <arg name="gui" default="true" />
    <arg name="headless" default="false" />
    <arg name="debug" default="false" />
I believe that the error is raised because the physics engine can't find some properties in the custom world file i have. I checked in the gazebo client (gui) and the iters and sor were 0. Despite that the simulation runs as expected without crashing.
Does anyone know how to fix this? I have found two similar questions (question1 and question2) in this forum but the answers given are inconclusive.
Thank you for your time.
Asked by Rellum on 2022-09-09 13:17:48 UTC
