gzclient seg faults before gui appears with no error message
Hello there,
I am receiving a segmentation fault when I try to run gzclient:
$ gzclient --verbose
Gazebo multi-robot simulator, version 11.10.2
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Connected to gazebo master @ http://192.168.0.20:11345
[Msg] Publicized address: 192.168.0.20
$ cat ~/.gazebo/client-11345/default.log
(1663121389 542961751) [Msg] Waiting for master.
(1663121389 552815735) [Msg] Connected to gazebo master @ http://192.168.0.20:11345
(1663121389 552850738) [Msg] Publicized address: 192.168.0.20
(1663121389 552987571) Loaded .ini file from: "/home/campbell/.gazebo/gui.ini"
$ tail ~/.gazebo/ogre.log
19:09:49: Creating resources for group Schemes
19:09:49: All done
19:09:49: Parsing scripts for resource group SkyX
19:09:49: Parsing script SkyX.material
19:09:49: Finished parsing scripts for resource group SkyX
19:09:49: Creating resources for group SkyX
19:09:49: All done
19:09:49: Added resource location '/usr/share/gazebo-11/media/rtshaderlib/' of type 'FileSystem' to resource group 'General'
19:09:49: Creating resource group ShaderGeneratorResourceGroup
19:09:49: Added resource location '/tmp/gazebo-campbell-rtshaderlibcache/' of type 'FileSystem' to resource group 'ShaderGeneratorResourceGroup'
I have installed gazebo per these instructions: https://classic.gazebosim.org/tutorials?tut=ros2_installing&cat=connect_ros (replacing "foxy" with "humble") I first tried via apt with no issue until I ran gazebo. Then uninstalled and built from source and had the same issue.
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.1 LTS
Release: 22.04
Codename: jammy
$ echo $ROS_DISTRO
humble
$ nvidia-smi
Tue Sep 13 19:20:26 2022
| NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 |
$ qtdiag
Qt 5.15.3 (x86_64-little_endian-lp64 shared (dynamic) release build; by GCC 11.3.0) on "xcb"
OS: Ubuntu 22.04.1 LTS [linux version 5.15.0-47-generic]
Architecture: x86_64; features: SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 AVX AVX2
LibGL Vendor: NVIDIA Corporation
Renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
Version: 4.6.0 NVIDIA 515.65.01
Shading language: 4.60 NVIDIA
Format: Version: 4.6 Profile: 2 Swap behavior: 0 Buffer size (RGB): 8,8,8 Depth buffer: 24
Profile: None (QOpenGLFunctions_4_6)
It must be some kind of issue with the GUI portion because I can run gzclient on my Mac and connect to gzserver running on my Ubuntu box. But I would love to be able to run both on my Ubuntu machine. Any ideas on how I can debug this further? Any help is greatly appreciated!
Asked by ck2050 on 2022-09-13 21:31:15 UTC
