Not able to run spawn_urdf tutorial with Garden
I am not able to run gz service -l.
I wasn't sure if this is a bug, so I thought of putting this here.
When I run gz sim empty.sdf I get following warnings in my terminal
libEGL warning: DRI2: failed to create dri screen
Then in another terminal when I run gz service -l, I get the following output
The 'gz' command provides a command line interface to the Gazebo Tools.
gz <command> [options]
List of available commands:
help: Print this help text.
gui: Launch graphical interfaces.
fuel: Manage simulation resources.
sim: Run and manage the Gazebo Simulator.
gazebo: Deprecated. Alias for sim.
sdf: Utilities for SDF files.
model: Print information about models.
plugin: Print information about plugins.
msg: Print information about messages.
log: Record or playback topics.
Options:
--force-version <VERSION> Use a specific library version.
--versions Show the available versions.
--commands Show the available commands.
Use 'gz help <command>' to print help for a command.
I face a similar output when I try to run commands related to gz topic too
Environment: OS: Ubuntu 20.04 Build: Binary Garden Installation GPU details:
Fri Sep 16 13:07:38 2022
| NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A |
| N/A 55C P8 N/A / N/A | 9MiB / 3072MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 936 G /usr/lib/xorg/Xorg 4MiB |
| 0 N/A N/A 1462 G /usr/lib/xorg/Xorg 4MiB |
Asked by radiantb on 2022-09-16 02:39:52 UTC
Thanks! This should be fixed in the next prerelease after this patch.
Asked by Carlos Agüero on 2022-09-23 09:55:43 UTC
