Error setting socket option
Hi, I installed GazeboSIm 11.12 on Ubuntu 20.04. I ran source /usr/share/gazebo-11/setup.sh and then when I run gazebo-11.12.0 it shows the GUI and at the same time it prints on the terminal this error Error setting socket option (IP_ADD_MEMBERSHIP). for 20 lines. Did I do anything wrong? What to change to get rid of this error message?
Thanks
Asked by endotjay on 2022-09-24 18:57:23 UTC
Hi, are you installing it in a VM, cloud or something similar?
Could you also paste the output of the command ifconfig? You might need to run sudo apt install net-tools if ifconfig isn't installed.
Asked by Carlos Agüero on 2022-09-25 05:12:49 UTC
