gazebo fails to load ign_ros2_control-system plugin
gazebo: gazebo citadel
ros distro: foxy
installed binaries: ros-foxy-ignition-citadel,ros-foxy-ign-ros2-control and ros-foxy-ign-ros2-control-demos
I was trying to setup the <ros2_control> tag for my robot to use with the ign_ros2_control/IgnitionSystem plugin, however when I try to spawn the robot into empty gazebo world, I get the following error message in the gazebo terminal
lukas@DESKTOP-QRS1BRB:~$ ign gazebo empty.sdf
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-lukas'
[Err] [SystemLoader.cc:66] Failed to load system plugin [ign_ros2_control-system]: couldn't find shared library.
here is the <ros2_control> tag
<ros2_control name="IgnitionSystem" type="system">
<hardware>
<plugin>ign_ros2_control/IgnitionSystem</plugin>
</hardware>
<joint name="link_1_joint">
<command_interface name="position">
<param name="min">-15</param>
<param name="max">15</param>
</command_interface>
<state_interface name="position"/>
<state_interface name="velocity"/>
<state_interface name="effort"/>
</ros2_control>
<gazebo>
<!-- Joint state publisher -->
<plugin filename="libign_ros2_control-system.so" name="ign_ros2_control">
<robot_param>robot_description</robot_param>
<robot_param_node>robot_state_publisher</robot_param_node>
<parameters>$(find inobot_config)/config/ros_controllers.yaml</parameters>
None of the demos work neither, when I try to launch the cart position demo I get the following output with no working system
Let me know if this is not the right place to post this issue as I am unsure if this is issue with gazebo or gzros2control, however I keep getting the same error msg (i.e. Failed to load system plugin) for other plugins such as diff_drive, camera, imu
Here is the output of the launch.log
1664774096.8416636 [INFO] [launch]: All log files can be found below /home/lukas/.ros/log/2022-10-03-06-14-56-834269-DESKTOP-QRS1BRB-19283
1664774096.8420956 [INFO] [launch]: Default logging verbosity is set to INFO
1664774097.0093417 [INFO] [ign gazebo-1]: process started with pid [19288]
1664774097.0096638 [INFO] [robot_state_publisher-2]: process started with pid [19291]
1664774097.0098433 [INFO] [create-3]: process started with pid [19293]
1664774097.4934983 [INFO] [create-3]: process has finished cleanly [pid 19293]
1664774097.5219979 [INFO] [ros2-4]: process started with pid [19356]
1664774108.1720819 [WARNING] [launch]: user interrupted with ctrl-c (SIGINT)
1664774108.1955278 [INFO] [robot_state_publisher-2]: process has finished cleanly [pid 19291]
1664774108.3028009 [ERROR] [ros2-4]: process has died [pid 19356, exit code 2, cmd 'ros2 control load_controller --set-state start joint_state_broadcaster'].
1664774113.1790979 [ERROR] [ign gazebo-1]: process[ign gazebo-1] failed to terminate '5' seconds after receiving 'SIGINT', escalating to 'SIGTERM'
1664774113.1800406 [INFO] [ign gazebo-1]: sending signal 'SIGTERM' to process[ign gazebo-1]
1664774113.1809649 [ERROR] [ign gazebo-1]: process has died [pid 19288, exit code -15, cmd 'ign gazebo -r -v 4 empty.sdf'].
Asked by lukas97 on 2022-10-03 15:37:33 UTC
I just tested the examples in docker with your set of binaries and it worked. Not sure what the problem is from looking at the logs. Can you also post the logs from your
~/.ros/log/2022-10-03-06-14-56-834269-DESKTOP-QRS1BRB-19283/?Asked by azeey on 2022-10-05 21:17:15 UTC
thanks, azeey, I appended the output of the
launch.logto the original postAsked by lukas97 on 2022-10-06 00:33:34 UTC
@azeey it worked for you? What is the requirement to run it? Is there any apt repo needed for this one? What about colcon build? Where should I use the colcon build at? I tried it another day when people asked me how and I couldn't figure it out lol See here: https://github.com/ros-controls/gz_ros2_control/issues/7#issuecomment-1239728096
I wanted to help them but i dont know how. Do you think you could refer us to the right route?
Asked by kakcalu13 on 2022-10-06 07:55:31 UTC
BTW @lukas97, your log says user pressed C to end. Prior to that event, was it just hanging for no reason?
Asked by kakcalu13 on 2022-10-06 07:56:04 UTC
From the
launch.log, it looks like you pressedctrl-cwithin 10 seconds of launch, as @kakcalu13 mentioned. Is that not the case?Asked by azeey on 2022-10-11 18:47:29 UTC
thanks, yes, I interrupted it as it threw a bunch of errors in the console output and nothing would happen - did not start the ros2 controllers
Asked by lukas97 on 2022-10-14 11:40:09 UTC
Can you run it longer (at least a minute) and send the logs?
Asked by azeey on 2022-10-14 12:40:36 UTC
