I am not able to run Gazebo on Docker (MacBook pro M1).
Hi, I am using a MacBook Pro Apple Silicon M1 Chip. On my system I pulled the docker image and when I tried to initiate the command for Gazebo, unfortunately I was not able to initiate it. Please find below the error I am getting while doing the aforementioned step.
**root@ed049c5273bc: # gazebo Error setting socket option (IP_MULTICAST_IF). Error setting socket option (IP MULTICAST IF). Did you set the environment variable IGN
_IP with a correct IP address? (172.17.0.2] seems an invalid local IP address. Using 127.0.0.1 as hostname. terminate called after throwing an instance of std::out of range' what(): vector:: M_ range check: n (which is 0) >= this >size() (which is 0 gemu: uncaught target signal 6 (Aborted). - core dumped**
Thanks in advance for your support.
Asked by Ankur Kohli on 2022-11-03 18:32:40 UTC
