How to download Gazebo on Ubuntu Jammy and ROS 2 ?
I currently use Ubuntu Jammy (22.04) and ROS 2 humble. I download on WSL 2 of window. I try to install Gazebo garden (source) to use with ROS2.The command I use is from gazebo install tutorial.
For the missing dependency from below error , I had check the ubuntu jammy , there is no available package appear on ubuntu search. Where could i find the package and how could I add it to ros dependency .
Command:
sudo apt -y install (sort−u(find . -iname ‘packages-‘lsb_release -cs’.apt’ -o -iname ‘packages.apt’ | grep -v ‘/.git/’) | sed ‘/gz|sdf/d’ | tr ‘\n’ ’ ')
The output of the command above :
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
E: Unable to locate package libogre-next-2.3-dev
E: Couldn’t find any package by glob ‘libogre-next-2.3-dev
Asked by LiKiu929 on 2022-11-22 18:16:40 UTC
Did you follow https://gazebosim.org/docs/garden/install_ubuntu?
Asked by azeey on 2022-12-05 15:13:10 UTC
