Modeling a non-standard manipulator
I have been trying to simulate a 'non-standard' open-chain robotic manipulator in Gazebo. The problem is that Gazebo assumes a simple kinematic chain (link-joint-link-joint-..) but this manipulator does not comply with this assumption. Here is how:
Assume that we have this 2-link manipulator:
if the first joint was rotated 90 degrees, this is how it should look like:
However, our manipulator will look like this:
This is because the two motors are placed on the base, and motor 2 is connected to joint 2 through a belt, while motor 1 is connected directly to joint 1.
Deriving the kinematics and dynamics has been done, but I want to also simulate it in Gazebo.
Any suggestions?
Thanks in advance!
Asked by Ayham on 2022-11-30 07:48:41 UTC
Have you looked into mimic joints? https://answers.gazebosim.org//question/24438/how-to-use-gazebo-mimic-joints-plugin/
Asked by azeey on 2022-12-08 19:23:30 UTC
