make a moving/rotating platform for driving a robot
Hello, I am trying to create a moving platform that can move in roll, pitch, yaw, Z. I want to test driving a robot on such a platform. I created a SDF platform and adapted this code for controlling the movement. but the ground plane keep the platform from rolling/pitching. And if I remove the ground platform both the robot and platform fall. Is this possible ? what am I doing wrong? My ground platform is here:
    <?xml version="1.0"?>
<sdf version="1.4">
    <model name="SMP">
        <pose>0 0 2.0 0 0 0.0</pose>
          <pose>0 0 0 0 0 0</pose>
          <mass>.1000</mass>
            <ixx>9.99999999e+10</ixx>
            <ixy>0.0</ixy>
            <ixz>0.0</ixz>
            <iyy>9.99999999e+10</iyy>
            <iyz>0.0</iyz>
            <izz>9.99999999e+10</izz>
        <gavity>0</gravity>
            <mesh>
              <uri>model://SMP/meshes/triangle.stl</uri>
              <scale>1 1 1 </scale>
          </mesh>
          <surface>
              <friction>
                <ode>
                  <mu>10</mu>
                  <mu2>10</mu2>
                </ode>
              </friction>
            </surface>
            <mesh>
          </mesh>
      <plugin name="plannar_mover_plugin" filename="libplannar_mover_plugin.so"/>
Asked by nagoldfarb on 2022-12-08 11:00:10 UTC
Your inertial numbers seem very extreme - where did you get those values?
Asked by Gavriel-CTO on 2022-12-08 11:59:30 UTC
If this is not just the typo here <gavity>0</gravity>, then the first gavity should be gravity. Gravity is enabled by default. Anyway, with beginning and ending tags not the same, I believe the SDF should have complained about invalid xml...
As for the object hitting the ground plane, I think that is expected as you are using physics on the model, and both your model and the ground have collisions, so they will hit each other. With gravity set to false and no colliding with the ground, the plane should move as expected.
Asked by Veerachart on 2022-12-12 21:43:39 UTC
