Error running "ign gazebo shapes.org" from tutorial
asked 2022-12-09 03:56:49 -0600
Vol gravatar image
Ubuntu 22.04. I’ve installed gazebo garden using Binary installation on Ubuntu instructions from this page: https://gazebosim.org/docs/garden/ins...
Then when I run the command "ign gazebo shapes.org" I get the following response: "Command 'ign' not found, but can be installed with: sudo apt install ignition-tools".
After installation of "ignition-tools" I get the following error: "I cannot find any available 'ign' command: * Did you install any ignition library? * Did you set the IGN_CONFIG_PATH environment variable? E.g.: export IGN_CONFIG_PATH=$HOME/local/share/ignition"
I also tried to install "libignition-gazebo" from this page: https://gazebosim.org/api/gazebo/6.3/... - no luck.
What is this "ign" command, and how can I install it?
answered 2022-12-16 08:42:06 -0600
alex-ssom gravatar image
If you're using Gazebo Garden. You should use the Garden version of the tutorials.
The ign gazebo command was deprecated in favor of gz sim
See: https://gazebosim.org/docs/garden/mig... for details on this migration.
TL;DR use gz sim shapes.sdf
Asked: 2022-12-09 03:56:49 -0600
Seen: 549 times
Last updated: Dec 16 '22
