laser_scan topic didn't publishing in ROS
Hello, I am making the simulation with laser scan. Here is how it is descripted in sdf:
<!-----LIDAR ------->
<link name="lidar_base">
<pose>0.000528 0.16822 1.2381 1.5708 0.013803 1.5708</pose>
<mass>1.2</mass>
<ixx>0.001087473</ixx>
<iyy>0.001087473</iyy>
<izz>0.001092437</izz>
<collision name='base_link_Chassis_fixed_joint_lump__Lidar_collision_1'>
<mesh>
<scale>1 1 1</scale>
<uri>model://stockchaser/meshes/Lidar.STL</uri>
</mesh>
<visual name='base_link_Chassis_fixed_joint_lump__Lidar_visual_1'>
<mesh>
</mesh>
<sensor type="ray" name="lidar_base">
<pose>0 0 -0.004645 1.5707 0 0</pose>
<ray>
<noise>
<type>gaussian</type>
<mean>0.0</mean>
<stddev>0.1</stddev>
</noise>
<range>
<min>0.05</min>
<max>70</max>
<resolution>0.02</resolution>
</range>
</ray>
<plugin name="laser" filename="libgazebo_ros_laser.so"/>
<joint name="lidar_joint" type="fixed">
<parent>base_link_Chassis</parent>
<child>lidar_base</child>
<pose>0 0 0 0 0 0</pose>
It seems that it works in simulation, here is the screenshot:
But there is no scan topic in rostopic list:
olesya@hellmachine:~$ rostopic list /clock
/gazebo/link_states
/gazebo/model_states
/gazebo/parameter_descriptions
/gazebo/parameter_updates
/gazebo/performance_metrics
/gazebo/setlinkstate
/gazebo/setmodelstate
/rosout
/rosout_agg
I launched ros_gazebo in verbose mode but there is no any errors connected with plugin.
This is how I am launching:
<arg name="debug" default="true" />
<arg name="gui" default="true" />
<arg name="pause" default="false" />
<arg name="world" default="$(find my_simulations)/world/empty_world.world" />
<arg name="world_name" value="$(arg world)" />
<arg name="debug" value="$(arg debug)" />
<arg name="gui" value="$(arg gui)" />
<arg name="paused" value="$(arg pause)" />
<arg name="use_sim_time" value="true" />
<arg name="verbose" value="true"/>
What should be wrong? Thank you in advance
Asked by Olesya on 2022-12-13 14:01:26 UTC
As far as I know, this plugin is a sensor plugin, so it should be here
<plugin name="laser" filename="libgazebo_ros_laser.so"/> <!-- here -->
Asked by Veerachart on 2022-12-18 21:19:35 UTC
So for future generations - I just mixed up formats. You should use URDF or xacro format
Asked by Olesya on 2022-12-21 10:33:17 UTC
