How to debug: [ros_gz_bridge]: Failed to create a bridge for topic
asked 2022-12-18 13:56:55 -0600
azazdeaz gravatar image
updated 2022-12-19 05:14:29 -0600
Hi There,
ros_gz_bridge reports failure while the parameters seem to be correct:
$ ros2 run ros_gz_bridge parameter_bridge /cmd_vel@geometry_msgs/Twist@gz.msgs.Twist
[INFO] [1671392523.581891853] [ros_gz_bridge]: Creating GZ->ROS Bridge: [/cmd_vel (gz.msgs.Twist) -> /cmd_vel (geometry_msgs/Twist)] (Lazy 0)
[WARN] [1671392523.582115037] [ros_gz_bridge]: Failed to create a bridge for topic [/cmd_vel] with ROS2 type [/cmd_vel] to topic [geometry_msgs/Twist] with Gazebo Transport type [gz.msgs.Twist]
I'm using Gazebo Garden on the osrf/ros:humble-desktop Docker image. I have a robot in the simulation that i can control with the Teleop widget on the /cmd_vel topic. I installed the ros-humble-ros-gz-bridge with apt.
What else should i check to find the cause of the issue?
Update
Using ignition.msgs.Twist instead of gz.msgs.Twist removes the error, (even though i'm using Gazebo Garden). But the messages are still not transferred.
It seems like Gazebo is using the gz. version of the message. This could explain why ROS2 messages have no effect on the simulation:
gz topic -i -t  /cmd_vel
Publishers [Address, Message Type]:
  tcp://172.17.0.1:39535, ignition.msgs.Twist
  tcp://172.17.0.1:42165, gz.msgs.Twist
Maybe i don't have some ROS message definitions installed? I installed gz-garden and ros-humble-gazebo-msgs from the official PPA.
For more info, ros2 topic info with the bridge, teleop_keyboard, and a ros2 echo running:
ros2 topic info -v /cmd_vel
Type: geometry_msgs/msg/Twist
Publisher count: 2
Node name: ros_gz_bridge
Node namespace: /
Topic type: geometry_msgs/msg/Twist
Endpoint type: PUBLISHER
GID: 01.0f.50.71.51.ab.45.39.01.00.00.00.00.00.12.03.00.00.00.00.00.00.00.00
QoS profile:
  Reliability: RELIABLE
  History (Depth): UNKNOWN
  Durability: VOLATILE
  Lifespan: Infinite
  Deadline: Infinite
  Liveliness: AUTOMATIC
  Liveliness lease duration: Infinite
Node name: teleop_twist_keyboard
Node namespace: /
GID: 01.0f.50.71.da.d3.49.82.01.00.00.00.00.00.11.03.00.00.00.00.00.00.00.00
QoS profile:
  Lifespan: Infinite
  Deadline: Infinite
Subscription count: 2
Node namespace: /
Endpoint type: SUBSCRIPTION
GID: 01.0f.50.71.51.ab.45.39.01.00.00.00.00.00.13.04.00.00.00.00.00.00.00.00
QoS profile:
  Lifespan: Infinite
  Deadline: Infinite
Node name: _ros2cli_205184
Node namespace: /
GID: 01.0f.50.71.80.21.50.1f.01.00.00.00.00.00.05.04.00.00.00.00.00.00.00.00
QoS profile:
  Lifespan: Infinite
  Deadline: Infinite
For reference, a question about probably the same issue on robotics.stackexchange: https://robotics.stackexchange.com/qu...
azazdeaz gravatar imageazazdeaz ( 2022-12-19 05:16:11 -0600 )edit
2
answered 2022-12-19 08:00:04 -0600
clydemcqueen gravatar image
Did you build from source? If not, this could be the problem. The pre-built bridge is looking for Fortress types on the gz topics, and failing to find them.
https://github.com/gazebosim/ros_gz
Thank you!
azazdeaz gravatar imageazazdeaz ( 2022-12-20 01:38:54 -0600 )edit
answered 2023-06-25 12:12:43 -0600
For anyone struggling with this, my issue was that the command for Garden should be: ros2 run ros_gz_bridge parameter_bridge /cmd_vel@geometry_msgs/msg/Twist@gz.m... NOT ros2 run ros_gz_bridge parameter_bridge /cmd_vel@geometry_msgs/Twist@gz.msgs....
Asked: 2022-12-18 13:56:55 -0600
Seen: 780 times
Last updated: Dec 19 '22
