GPU-accelerated ignition gazebo on WSLg
I'm having trouble running gazebo ignition on WSL2 22.04 since it comes up with display issues. I am using wslg Running gazebo works fine but running anything in gazebo ignition leads to it crashing once it gets past the startup menu. I googled this problem and it seemed like people had it and fixed it by exporting LD_PRELOAD="/usr/lib/x86_64-linux-gnu/libstdc++.so.6" however that also did not work for me. Following this thread did help by using CPU rendering instead of GPU rendering however it is much slower and would prefer to use GPU rendering if possible. Following this video and using xserver instead did not change the problem. It seems this issue is very similar to the problem I'm having however mine crashes once it gets past the startup menu.
LIBGL_DEBUG=verbose ign gazebo
libGL: MESA-LOADER: dlopen(/usr/lib/x86_64-linux-gnu/dri/swrast_dri.so)
libGL: Can't open configuration file /etc/drirc: No such file or directory.
libGL: Can't open configuration file /home/user/.drirc: No such file or directory.
libEGL warning: MESA-LOADER: failed to open vgem: /usr/lib/dri/vgem_dri.so: cannot open shared object file: No
such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
libEGL warning: NEEDS EXTENSION: falling back to kms_swrast
terminate called after throwing an instance of 'Ogre::UnimplementedException'
what(): OGRE EXCEPTION(9:UnimplementedException): in GL3PlusTextureGpu::copyTo at /build/ogre-next-
UFfg83/ogre-next-2.2.5+dfsg3/RenderSystems/GL3Plus/src/OgreGL3PlusTextureGpu.cpp (line 677)
Stack trace (most recent call last) in thread 11682:
#10 Object "[0xffffffffffffffff]", at 0xffffffffffffffff, in
#9 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f32f6b2f9ff, in
#8 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f32f6a9db42, in
#7 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7f32f130b99d, in
#6 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7f32f1309f90, in qTerminate()
#5 Object "/usr/lib/x86_64-linux-gnu/libstdc++.so.6", at 0x7f32f70762b6, in std::terminate()
#4 Object "/usr/lib/x86_64-linux-gnu/libstdc++.so.6", at 0x7f32f707624b, in
#3 Object "/usr/lib/x86_64-linux-gnu/libstdc++.so.6", at 0x7f32f706abbd, in
#2 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f32f6a317f2, in abort
#1 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f32f6a4b475, in raise
#0 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f32f6a9fa7c, in pthread_kill
Aborted (Signal sent by tkill() 11625 1000)`
I also sometimes get this error as well and tried to fix it by changing permissions but it blue-screened my pc.
ign gazebo
libEGL warning: failed to open /dev/dri/renderD128: Permission denied
Asked by KSpooky on 2023-01-02 19:23:16 UTC
