Ignition gazebo citadel can no longer load worlds from fuel.gazebosim.org
asked 2023-01-09 07:10:46 -0500
GuillaumeB gravatar image
updated 2023-01-09 07:11:19 -0500
In a fresh Ubuntu 20.04 VM with Ignition Gazebo citadel, version 3.14.0 installed, I cannot load worlds from fuel.gazebosim.org.
Previously I was able to do so.
For example: ign gazebo "https://fuel.gazebosim.org/1.0/OpenRobotics/worlds/Test_shapes" was properly starting gazebo and loading the world (I could also do it with more complex worlds like the Tugbot_warehouse).
This command no longer works. Now this command gives:
[Err] [Server.cc:181] Error Code 13 Msg: Directory doesn't exist[/home/ubuntu/.ignition/fuel/fuel.ignitionrobotics.org/openrobotics/models/ground plane/tip] [Err] [Server.cc:181] Error Code 13 Msg: Directory doesn't exist[/home/ubuntu/.ignition/fuel/fuel.ignitionrobotics.org/openrobotics/models/sun/tip]
And the same is happening with any other world from fuel that I tried. For every model, the "tip" folder is missing.
Is Gazebo Citadel still expected to work with Fuel? What would be the way to load Fuel worlds from Gazebo Citadel?
answered 2023-01-12 23:10:06 -0500
azeey gravatar image
This is a bug in Gazebo which should be fixed by https://github.com/gazebosim/gz-fuel-...
answered 2023-01-12 13:10:12 -0500
alex-ssom gravatar image
updated 2023-01-12 13:10:34 -0500
I ran into the same issue on Gazebo Fortress. The easiest way I found to fix this was to download the content locally. image description
Asked: 2023-01-09 07:10:46 -0500
Seen: 594 times
Last updated: Jan 12 '23
