How large dae file can ignition use ?
When I try to run large world, I found some error like below.
How large dae file can the ignition run ?
I use Garden v1.7.0.
stmoon@stmoon-XPS-9320 ~/.gz/fuel/fuel.ignitionrobotics.org/openrobotics/models/island gz sim model.sdf
../src/intel/isl/isl.c:2220: FINISHME: ../src/intel/isl/isl.c:isl_surf_supports_ccs: CCS for 3D textures is disabled, but a workaround is available.
terminate called after throwing an instance of 'Ogre::InvalidStateException'
what(): OGRE EXCEPTION(1:InvalidStateException): This macroblock has already been destroyed! in HlmsManager::destroyMacroblock at ./OgreMain/src/OgreHlmsManager.cpp (line 231)
Stack trace (most recent call last) in thread 15461:
#31 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7f34f73ff701, in QApplicationPrivate::notify_helper(QObject*, QEvent*)
#30 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7f34f7ca5b99, in QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*)
#29 Object "/usr/lib/x86_64-linux-gnu/gz-sim-7/plugins/gui/libGzSceneManager.so", at 0x7f349807c680, in gz::sim::v7::GzSceneManager::eventFilter(QObject*, QEvent*)
#28 Object "/lib/x86_64-linux-gnu/libgz-sim7-rendering.so.7", at 0x7f349076d9d5, in gz::sim::v7::RenderUtil::Update()
#27 Object "/lib/x86_64-linux-gnu/libgz-sim7-rendering.so.7", at 0x7f34907b061b, in gz::sim::v7::SceneManager::CreateVisual(unsigned long, sdf::v13::Visual const&, unsigned long)
#26 Object "/lib/x86_64-linux-gnu/libgz-sim7-rendering.so.7", at 0x7f34907aece9, in gz::sim::v7::SceneManager::LoadGeometry(sdf::v13::Geometry const&, gz::math::v7::Vector3<double>&, gz::math::v7::Pose3<double>&)
#25 Object "/lib/x86_64-linux-gnu/libgz-rendering7.so.7", at 0x7f34d01f4b03, in gz::rendering::v7::BaseScene::CreateMesh(gz::rendering::v7::MeshDescriptor const&)
#24 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f338a9f6c13, in gz::rendering::v7::Ogre2Scene::CreateMeshImpl(unsigned int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, gz::rendering::v7::MeshDescriptor const&)
#23 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f338a9d5c48, in gz::rendering::v7::Ogre2MeshFactory::Create(gz::rendering::v7::MeshDescriptor const&)
#22 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f338a9d1366, in gz::rendering::v7::Ogre2SubMeshStoreFactory::Create()
#21 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f338a9d8fab, in gz::rendering::v7::Ogre2SubMeshStoreFactory::CreateSubMesh(unsigned int)
#20 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f338a9c25f0, in
#19 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f338a9b79fe, in
#18 Object "/lib/x86_64-linux-gnu/libgz-rendering7.so.7", at 0x7f34d01f1de5, in gz::rendering::v7::BaseScene::CreateMaterial(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)
#17 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f338a93df58, in
#16 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f338a94ca39, in
#15 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f338a9fe8f9, in
#14 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f338a9b1620, in gz::rendering::v7::Ogre2Material::~Ogre2Material()
#13 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f338a9b08a3, in gz::rendering::v7::Ogre2Material::Destroy()
#12 Object "/usr/lib/x86_64-linux-gnu/OGRE-2.3/libOgreNextMain.so.2.3.1", at 0x7f338a496ba3, in Ogre::Hlms::destroyDatablock(Ogre::IdString)
#11 Object "/usr/lib/x86_64-linux-gnu/OGRE-2.3/libOgreNextHlmsPbs.so.2.3.1", at 0x7f338a28067c, in Ogre::HlmsPbsDatablock::~HlmsPbsDatablock()
#10 Object "/usr/lib/x86_64-linux-gnu/OGRE-2.3/libOgreNextMain.so.2.3.1", at 0x7f338a4ac6d0, in Ogre::HlmsDatablock::~HlmsDatablock()
#9 Object "/usr/lib/x86_64-linux-gnu/OGRE-2.3/libOgreNextMain.so.2.3.1", at 0x7f338a3df843, in
#8 Object "/lib/x86_64-linux-gnu/libgcc_s.so.1", at 0x7f34f95fc6bc, in _Unwind_Resume
#7 Object "/lib/x86_64-linux-gnu/libgcc_s.so.1", at 0x7f34f95fbc63, in
#6 Object "/lib/x86_64-linux-gnu/libstdc++.so.6", at 0x7f34f96b2998, in __gxx_personality_v0
#5 Object "/lib/x86_64-linux-gnu/libstdc++.so.6", at 0x7f34f96b2228, in
#4 Object "/lib/x86_64-linux-gnu/libstdc++.so.6", at 0x7f34f96b324b, in
#3 Object "/lib/x86_64-linux-gnu/libstdc++.so.6", at 0x7f34f96a7bbd, in
#2 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f34fdf6e7f2, in abort
#1 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f34fdf88475, in raise
#0 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f34fdfdca7c, in pthread_kill
Aborted (Signal sent by tkill() 15264 1000)
Asked by stmoon on 2023-01-27 21:04:04 UTC
