Gazebo not loading diffuse texture image
I have a world file generated by a python code. This world file contains a heightmap with texture from images as seen below.
<model name="heightmap">
<visual name="visual_abcedf">
<heightmap>
<use_terrain_paging>false</use_terrain_paging>
<texture>
<diffuse>file://materials/textures/grass_color.jpg</diffuse>
<normal>file://materials/textures/grass_normal.jpg</normal>
<size>4</size>
</texture>
<texture>
<diffuse>file://materials/textures/dirt_diffusespecular.png</diffuse>
<normal>file://materials/textures/flat_normal.png</normal>
<size>1</size>
</texture>
<!-- <texture>
<size>4</size>
</texture> -->
<!-- Without this unused 3. texture the blend between the first 2 doesn't work -->
<texture>
<diffuse>file://materials/textures/fungus_diffusespecular.png</diffuse>
<size>1</size>
</texture>
<blend>
<min_height>0.2</min_height>
<fade_dist>0.05</fade_dist>
</blend>
<!-- <blend>
<min_height>0.30000000000000004</min_height>
</blend> -->
<blend>
<min_height>4</min_height>
<fade_dist>5</fade_dist>
</blend>
<uri>file://virtual_maize_field_heightmap.png</uri>
<size>14.94 14.94 0.4</size>
<pos>0 0 0</pos>
</heightmap>
<heightmap>
<pos>0 0 0</pos>
</heightmap>
When I launch the file that loads the world from the original package where I got the repo, it works fine showing this:
But when I use the world file and copy the media files and directory to my own package, it shows this:
This means the
I have tried the configuration below in my package.xml but still didn't work:
<export>
<gazebo_ros gazebo_media_path="${prefix}" gazebo_model_path="${prefix}/models" gazebo_resource_path="${prefix}/models" />
All files directory were duly checked and correct but the textures are not loading while the
Asked by robotempire on 2023-02-06 07:43:48 UTC
