IMU added in Gazebo and data published via ROS all zero
I modified the SDF file, adding the IMU sensor as this: image description
And then I try publishing the IMU data using PYTHON as this: image description
But when I use
rtopic echo /Imu_1
to show the data, they are all zero as this: image description
Where is it I am wrong? Thanks!
Asked by sslzykk on 2023-03-10 04:13:51 UTC
When using the imu gazebo_plugin. The plugin will send out automatically his detected IMU parameters depending on his situation in Gazebo environment. So when you are controlling the robot with the cmd_vel the acceleration in x direction of the IMU data will be updated accordingly.
There is no need to send out the IMU data yourself.
Hope this helps.
Asked by Nobel on 2023-03-13 04:40:57 UTC
Actually I am using PX4-ROS-Gazebo to simulate drone systems, are you familiar with this? The IMU added just publishes all-zero data
Asked by sslzykk on 2023-03-14 04:31:37 UTC
