Texture of object loading as black with dots and text
asked 2023-03-14 20:53:51 -0500
mmDrone gravatar image
For some reason the texture on my mesh file loads as black for Gazebo 11 with ROS Noetic (gazebo fortress). The texture setup I have will load and configure perfectly fine for Gazebo garden on a different system with ROS2 Humble.. For some reason, when I load the same exact object into the predecessor version, the object renders with a black layer that has text and dots in it sometimes around the object. When I zoom in close onto the object, I can see through the black shielding layer and observe the true colors of the object. Does anyone know why this could be happening?
Can you clarify if you're using Gazebo-classic (Gazebo 11) or Gazebo Fortress? Also, can you provide a minimal example that shows the problem?
azeey gravatar imageazeey ( 2023-03-16 10:57:19 -0500 )edit
answered 2023-03-16 12:01:26 -0500
chutsu gravatar image
updated 2023-03-16 12:05:37 -0500
The way the new Gazebo Garden loads models with textures is totally different to how it used to be. See "Textures" towards the bottom of this page: https://gazebosim.org/api/gazebo/3.7/...
Took some creative google search to find this information. But the TLDR is instead of importanting a model texture the old OGRE way where you defined a .material file that ogre reads, you just import a MTL + OBJ or DAE file.
If you know how to use Blender it isn't too bad. You can create your 3D model with blender and then export it to MTL + OBJ (make sure you use PBR + Relative paths), or DAE (easier) file format. Then include the model as
  <mesh>uri://PATH_TO_MODEL</mesh>
^ where PATH_TO_MODEL is the folder name of your model with the appropriate model.sdf model.conf and other files.
Asked: 2023-03-14 20:53:51 -0500
Seen: 33 times
Last updated: Mar 16
