How to control simulation speed from API ?
I launch and interact with Gazebo from the API, and I would like to programmatically change the max_step_size
attribute from a (c++) program. For now, I can change it from the .sdf file of my world, like the following :
<physics name="4ms" type="ode">
<max_step_size>0.004</max_step_size>
<real_time_factor>-1.0</real_time_factor>
<real_time_update_rate>250</real_time_update_rate>
</physics>
I set real_time_factor
to -1 because I don't want it to interfere with the steps of the simulation. I want Gazebo to aim at a running speed of max_step_size
* real_time_update_rate
In am able to control real_time_update_rate
from the ServerConfig API with ServerConfig.SetUpdateRate() :
// Object to pass custom configuration to the server
gz::sim::ServerConfig serverConfig;
// Populate with some configuration, for example, the SDF file to load
serverConfig.SetSdfFile("/home/theotime/simulation_ws/src/worlds/3_UAVS.sdf");
serverConfig.SetUpdateRate(250); // in Hz
// Instantiate server
gz::sim::Server server(serverConfig);
In essence, I would like to have a ServerConfig.SetMaxStepSize(), do you know if there is a way to do that ?
- Gazebo Garden (so gz-sim7)
- Ubuntu 22.04
Thanks in advance !
Asked by TheotimeBalaguer on 2023-03-22 03:45:01 UTC
