Question with gazebo plugin libgazebo_ros_planar_move.so
Hi all.
So I'm trying to use libgazebo_ros_planar_move.so plugin in my xacro file.
I want to know what tag that use to publish odom transform and wheel transform and other wheel setting.Or some document to see.
Like libgazebo_ros_diff_drive.so there is like <wheel_separation> tag to define wheel seperation length, <publish_odom_tf> and <publish_wheel_tf> to publish odom and wheel transform,but I can't find any document about planar move plugin
This is my plugin xacro with planar_move plugin with this ref
<?xml version="1.0"?>
<gazebo>
<plugin name="psuedo_mecanum" filename="libgazebo_ros_planar_move.so">
<left_rear_joint>wheel_3_joint</left_rear_joint>
<right_rear_joint>wheel_2_joint</right_rear_joint>
<left_front_joint>wheel_4_joint</left_front_joint>
<right_front_joint>wheel_1_joint</right_front_joint>
<wheel_separation>0.72</wheel_separation>
<wheel_radius>0.1</wheel_radius>
<wheel_accel>1</wheel_accel>
<wheel_torque>0.2</wheel_torque>
<odometryRate>20.0</odometryRate>
I want to see something like this
I'm using Ubuntu 20.04 with ros2 Foxy,gazebo 11.11.0
Thanks all
Asked by dandog on 2023-04-04 15:16:44 UTC
