How do i spawn multiple robots in gazebo
I want to spawn multiple robot in a gazebo world but if I spawn more than one Robot Gazebo crashes.
The launch file:
def generate_launch_description():
with open("environment_vars.yaml", "r") as stream:
try:
environment_yaml = yaml.safe_load(stream)
print(environment_yaml)
except yaml.YAMLError as exc:
print(exc)
ld = LaunchDescription()
use_sim_time =True
for n in range(4):
namespace="rb"+str(n)
robot_xml = xacro.process_file(
os.path.join(
get_package_share_directory("rb_theron_description"),
"robots",
environment_yaml["robot"]+".urdf.xacro",
mappings={"prefix": environment_yaml["prefix"]},
).toxml()
declare_robot_model_cmd = DeclareLaunchArgument(
"robot_name",
default_value="rb_theron",
description="name of the robot in the simulation",
start_robot_state_publisher_cmd = Node(
name="robot_state_publisher",
package="robot_state_publisher",
executable="robot_state_publisher",
output="screen",
parameters=[{"use_sim_time": use_sim_time}, {"robot_description": robot_xml}],
remappings=[('/tf', 'tf'), ('/tf_static','tf_static')],
spawn_robot_cmd = Node(
package="ros_gz_sim",
executable="create",
output="screen",
arguments=["-name",
"tb_"+str(n),
"-topic",
"robot_description",
"-z",
"0.2",
"-x",
str(-2+-2*n),
"-y",
"0",
"-Y",
"0",
group = GroupAction([
PushRosNamespace(namespace=namespace),
declare_robot_model_cmd,
start_robot_state_publisher_cmd,
spawn_robot_cmd,
ld.add_action(group)
return ld
The error Message from Gazebo:
I use ROS2 Humble together with gazebo garden.
Thanks all
Asked by Torben on 2023-04-06 01:34:41 UTC
