Robot jumps up in the air, why?
Hi, its my first post. So I am trying to write a urdf for my real robot and test/program it in a gazebo world.
Problem: my launch file spawns my robot with a paused world. When I un-pause it, it does this weird flip/jump/fly thing.
Solutions tried: Spawn robot just of the ground > same thing''''' used gazebo "view" of collisions and so on > looks fine to a newbeee''''''''' played with inertia values > no help''''''' ..... and bunch of other stuff
what does make a difference is when I comment out my caster link, the robot behaves normal? I am sure... no weirdness in gazebo.
Might have some thing to do with the small inertia's of the links?
A side node: I know about xacros > lets get it working first, then go there''''''
Cant attach URDF file so here is the caster link snip:
<!--.............................................................caster_link...................................................................-->
<link name="sphere_link">
<visual>
<origin xyz="0.0 0.0 0.0" rpy="0.0 0.0 0.0"/>
<sphere radius="0.026"/>
<collision>
<mass value="0.002"/>
<inertia ixx="0.0000015417" ixy="0.0" ixz="0.0" iyy="0.0000015417" iyz="0.0" izz="0.0000004"/>
<!--I added 1x zero to all inertia calculations to get gazebo view of enertia looking write? all sceuars?-->
<!--gazebo reference="sphere_link"> gazebo tags outside links, posibly in one gazebo tag
</gazebo-->
<joint name="sphere_joint" type="fixed">
<parent link="caster_link"/>
<child link="sphere_link"/>
<origin xyz="0.0 -0.008 -0.02" rpy="0.0 0.0 0.0"/>
<link name="caster_link">
<visual>
<cylinder radius="0.0095" length="0.05"/>
<collision>
<cylinder radius="0.001" length="0.5"/>
<gazebo reference="caster_link">
<joint name="caster_joint" type="continuous">
<parent link="base_link"/>
<child link="caster_link"/>
<axis xyz="0 0 1"/>
<origin xyz="0.0 -0.089 0.045" rpy="0 0 0"/>
How does one share the complete code?
Asked by TK on 2023-04-13 06:10:40 UTC
never mind,, the length of the collision missed a "0" so collision cylinder way to long and impacting ground plane.
Asked by TK on 2023-04-15 04:44:49 UTC
