Segmentation Camera and Label plugin fails for spawned models
Dear community,
we have recently found out, that the segmentation camera in conjunction with the label plugin (ignition::gazebo::systems::Label) only works for models, which are already defined before startup in the *.world.
If we are spawning models during runtime of the simulation, the labels of the spawned models are not visualized. For spawning during runtime we used the create script from rosigngazebo in a launch file:
<node pkg="ros_ign_gazebo" type="create" name="$(anon ros_ign)" output="$(arg output)" args=""/>
In both cases the model was defined with the plugin in such way:
  <plugin filename="ignition-gazebo-label-system" name="ignition::gazebo::systems::Label">
        <label>10</label>
Since we would like to append models during runtime and to be detected by the segmentation camera, any help would be appreciated to solve this issue.
BR.
Asked by Illuminatur on 2023-04-19 02:54:26 UTC
