Unable to install Gazebo on MacOS Ventura
Hi there,
i am running a MacBook Pro with the M1 Pro Chip and Ventura.
I followed this Tutorial to install the binaries of Gazebo on MacOS Binary Installation on MacOS.
I always end up with the same error. Here is a snippet from the command prompt. This snippet starts after many packages have been downloaded
==> Installing osrf/simulation/gz-garden dependency: gz-common5
==> cmake .. -DBUILD_TESTING=Off -DCMAKE_INSTALL_RPATH=@loader_path/../lib
==> make install
Last 15 lines from /Users/jantoehr/Library/Logs/Homebrew/gz-common5/02.make:
[ 81%] Building CXX object graphics/src/CMakeFiles/gz-common5-graphics.dir/Skeleton.cc.o
# There were many many lines of logs here which I excluded for readability purposes
[ 87%] Built target gz-common5-graphics
[ 87%] Built target doc
make: *** [all] Error 2
If reporting this issue please do so at (not Homebrew/brew or Homebrew/homebrew-core):
https://github.com/osrf/homebrew-simulation/issues
Did anyone on MacOS encounter the same issue and was able to resolve it?
I would appreciate any kind of help :)
Asked by janto on 2023-04-19 05:07:06 UTC
Hi, have you solved this issue? I have the same problem on my Apple M1 Ventura 13.3.1
Asked by PButov on 2023-07-25 06:32:36 UTC
