Gazebo Sim crashes on start up on Ubuntu 22.04. in a Virtual Machine from Parallels on MacOS
Hi there,
I own a MacBook Pro with a M1 Pro Chip on Ventura. The Gazebo documentation recommends running Gazebo on Ubuntu for stability reasons.
I decided to use Parallels (Parallels) to install Ubuntu 22.04. on a Virtual Machine. It is quite easy and takes less then 5-10 Minutes.
Next I straight opened the command prompt and followed the instructions on how to install the binaries on Ubuntu Binary Installation on Ubuntu.
After successful installation I run Gazebo withgz sim
. The command prompt outputs the following logs...
Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
libGL error: pci id for fd 42: 1ab8:0010, driver (null)
pci id for fd 43: 1ab8:0010, driver (null)
The Gazebo Quick Start Window poped up and showed me the information that I am running Gazebo Garden v 7.0.0.
When I click on Empty and afterwards click RUN, a second window with Gazebo Sim shows up for a second and exits suddenly with a User Alert message from Ubuntu that ruby3.0 has stopped unexpectedly.
Here are the logs from the command prompt...
libGL error: pci id for fd 51: 1ab8:0010, driver (null)
pci id for fd 53: 1ab8:0010, driver (null)
libEGL warning: pci id for fd 70: 1ab8:0010, driver (null)
pci id for fd 71: 1ab8:0010, driver (null)
terminate called after throwing an instance of 'Ogre::UnimplementedException'
what(): OGRE EXCEPTION(9:UnimplementedException): in GL3PlusTextureGpu::copyTo at ./RenderSystems/GL3Plus/src/OgreGL3PlusTextureGpu.cpp (line 685)
Stack trace (most recent call last):
#31 Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffafafb06b, in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)
#30 Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffafb5b523, in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#29 Object "/lib/aarch64-linux-gnu/libglib-2.0.so.0", at 0xffffae932f13, in g_main_context_iteration
#28 Object "/lib/aarch64-linux-gnu/libglib-2.0.so.0", at 0xffffae98a76b, in
#27 Object "/lib/aarch64-linux-gnu/libglib-2.0.so.0", at 0xffffae935a6f, in g_main_context_dispatch
#26 Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffafb5c057, in
#25 Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffafafff87, in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*)
#24 Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffafafcb8f, in QCoreApplication::notifyInternal2(QObject*, QEvent*)
#23 Object "/lib/aarch64-linux-gnu/libQt5Widgets.so.5", at 0xffffb0fa2abf, in QApplicationPrivate::notify_helper(QObject*, QEvent*)
#22 Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffafb2cfd3, in QObject::event(QEvent*)
#21 Object "/usr/lib/aarch64-linux-gnu/gz-gui-7/plugins/libMinimalScene.so", at 0xffff98e77e07, in gz::gui::plugins::RenderWindowItem::Ready()
#20 Object "/usr/lib/aarch64-linux-gnu/gz-gui-7/plugins/libMinimalScene.so", at 0xffff98e77947, in
gz::gui::plugins::RenderThread::Initialize[abi:cxx11]()
#19 Object "/usr/lib/aarch64-linux-gnu/gz-gui-7/plugins/libMinimalScene.so", at 0xffff98e83d17, in gz::gui::plugins::RenderThreadRhiOpenGL::Initialize[abi:cxx11]()
#18 Object "/usr/lib/aarch64-linux-gnu/gz-gui-7/plugins/libMinimalScene.so", at 0xffff98e7b13f, in gz::gui::plugins::GzRenderer::Initialize[abi:cxx11]()
#17 Object "/lib/aarch64-linux-gnu/libgz-rendering7.so.7", at 0xffff6c173d23, in gz::rendering::v7::BaseRenderEngine::CreateScene(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)
#16 Object "/lib/aarch64-linux-gnu/libgz-rendering7.so.7", at 0xffff6c17b74f, in gz::rendering::v7::BaseRenderEngine::CreateScene(unsigned int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)
#15 Object "/lib/aarch64-linux-gnu/libgz-rendering7.so.7", at 0xffff6c1871e7, in
gz::rendering::v7::BaseScene::CreateMaterials()
#14 Object "/usr/lib/aarch64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0xffff50193e33, in gz::rendering::v7::Ogre2Material::SetTextureMapImpl(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, Ogre::PbsTextureTypes)
#13 Object "/usr/lib/aarch64-linux-gnu/OGRE-2.3/libOgreNextMain.so.2.3.1", at 0xffff4fdfb46b, in Ogre::TextureGpuManager::_waitFor(Ogre::TextureGpu*, bool)
#12 Object "/usr/lib/aarch64-linux-gnu/OGRE-2.3/libOgreNextMain.so.2.3.1", at 0xffff4fdfb0af, in Ogre::TextureGpuManager::_update(bool)
#11 Object "/usr/lib/aarch64-linux-gnu/OGRE-2.3/libOgreNextMain.so.2.3.1", at 0xffff4fcdebaf, in Ogre::ObjCmdBuffer::execute()
#10 Object "/usr/lib/aarch64-linux-gnu/OGRE-2.3/libOgreNextMain.so.2.3.1", at 0xffff4fcdcf37, in Ogre::ObjCmdBuffer::NotifyDataIsReady::execute()
#9 Object "/usr/lib/aarch64-linux-gnu/OGRE-2.3/libOgreNextMain.so.2.3.1", at 0xffff4fdecef3, in Ogre::TextureFilter::GenerateHwMipmaps::_executeSerial(Ogre::TextureGpu*)
#8 Object "/usr/lib/aarch64-linux-gnu/OGRE-2.3/OGRE/RenderSystem_GL3Plus.so", at 0xffff4f742633, in Ogre::GL3PlusTextureGpu::copyTo(Ogre::TextureGpu*, Ogre::TextureBox const&, unsigned char, Ogre::TextureBox const&, unsigned char, bool, Ogre::CopyEncTransitionMode::CopyEncTransitionMode, Ogre::CopyEncTransitionMode::CopyEncTransitionMode)
#7 Object "/usr/lib/aarch64-linux-gnu/OGRE-2.3/OGRE/RenderSystem_GL3Plus.so", at 0xffff4f704997, in
#6 Object "/lib/aarch64-linux-gnu/libstdc++.so.6", at 0xffffb2d12d23, in __cxa_throw
#5 Object "/lib/aarch64-linux-gnu/libstdc++.so.6", at 0xffffb2d12a3f, in std::terminate()
#4 Object "/lib/aarch64-linux-gnu/libstdc++.so.6", at 0xffffb2d129db, in
#3 Object "/lib/aarch64-linux-gnu/libstdc++.so.6", at 0xffffb2d151fb, in __gnu_cxx::__verbose_terminate_handler()
#2 Object "/lib/aarch64-linux-gnu/libc.so.6", at 0xffffb6d3712f, in abort
#1 Object "/lib/aarch64-linux-gnu/libc.so.6", at 0xffffb6d4a67b, in raise
#0 Object "/lib/aarch64-linux-gnu/libc.so.6", at 0xffffb6d8f200, in
Aborted (Signal sent by tkill() 8540 1000)
Can anyone help me with this issue or explain to me what I am doing wrong? I spend some time trying to resolve it on my own without any success.
I appreciate any kind of suggestion! :)
Asked by janto on 2023-04-19 07:22:15 UTC
