mobile articulated robot wheels slipping instead of rolling
Hi there everyone and thanks for helping. A quick bit of background, I've built an articulated center steering four(4) wheeled mobile robot. I'm struggling to find any navigation packages which suit this type of geometry (currently using TEB nav, badly) so thought I would try RL (reinforcement learning) using robogym but firstly I need my robot to work properly in the simulator.
This brings me to my problem, when I articulate in the sim, the front wheels just slide sideways. I have an animated GIF of the real robot and one of the sim robot (which I cant add to this post because I don't have any karma)
After you launch all the nodes and everything is running if you publish a command to the controller manager to rotate the center steering you will see the front section rotate which will slide the wheels (no roller or rotation). I reality it should bend in the middle and all wheels should turn slightly.
Why are my wheels sliding? I have tried heaps of different 'mu' values, I've tried conemodel friction, I've tried bullet physics, I've tried the fdir option, adjusting the contactsurface_layer distance, nothing seems to make any difference. Any help is really appreciated, thanks in advance..
Run this command to articulate:
$ rostopic pub /artmule_body/fpj_position_controller/command std_msgs/Float64 "data: -0.50"
This is my world launch file /artmule_body/launch/gazebo.launch:
  <launch>
        <!-- these are the arguments you can pass this launch file, for example paused:=true -->
        <arg name="use_sim_time" default="true"/>
        <arg name="extra_gazebo_args" default=""/>
        <arg name="recording" default="false"/>
        <arg name="headless" default="false"/>
        <arg name="debug" default="false"/>
        <arg name="physics" default="ode"/>
        <arg name="verbose" default="false"/>
        <arg name="output" default="screen"/>
        <arg name="world_name" default="$(find artmule_body)/world/empty_world.world"/>
        <arg name="respawn_gazebo" default="false"/>
        <arg name="use_clock_frequency" default="false"/>
        <arg name="pub_clock_frequency" default="100"/>
        <arg name="enable_ros_network" default="true" />
        <arg name="server_required" default="false"/>
        <arg name="gui_required" default="false"/>
        <!-- set use_sim_time flag -->
        <param name="/use_sim_time" value="$(arg use_sim_time)"/>
        <!-- set command arguments -->
        <arg unless="$(arg paused)" name="command_arg1" value=""/>
        <arg     if="$(arg paused)" name="command_arg1" value="-u"/>
        <arg unless="$(arg recording)" name="command_arg2" value=""/>
        <arg     if="$(arg recording)" name="command_arg2" value="-r"/>
        <arg unless="$(arg verbose)" name="command_arg3" value=""/>
        <arg     if="$(arg verbose)" name="command_arg3" value="--verbose"/>
        <arg unless="$(arg debug)" name="script_type" value="gzserver"/>
        <arg     if="$(arg debug)" name="script_type" value="debug"/>
        <!-- start gazebo server-->
        <group if="$(arg use_clock_frequency)">
                  <param name="gazebo/pub_clock_frequency" value="$(arg pub_clock_frequency)" />
        </group>
        <group>
                  <param name="gazebo/enable_ros_network" value="$(arg enable_ros_network)" />
        </group>
        <node name="gazebo" pkg="gazebo_ros" type="$(arg script_type)" respawn="$(arg respawn_gazebo)" output="$(arg output)"
        args="$(arg command_arg1) $(arg command_arg2) $(arg command_arg3) -e $(arg physics) $(arg extra_gazebo_args) $(arg world_name)"
required="$(arg server_required)" />
        <!-- start gazebo client -->
        <group if="$(arg gui)">
                  <node name="gazebo_gui" pkg="gazebo_ros" type="gzclient" respawn="false" output="$(arg output)" args="$(arg command_arg3)"
  required="$(arg gui_required)"/>
        </group>
        <node
          name="tf_footprint_base"
          pkg="tf"
          type="static_transform_publisher"
          args="0 0 0 0 0 0 base_link base_footprint 40" />
        <!-- Load the URDF into the ROS Parameter Server -->
        <param name="robot_description" command="cat $(find artmule_body)/urdf/artmule_body.urdf" />
        <!-- Run a python script to the send a service call to gazebo_ros to spawn a URDF robot -->
        <node name="urdf_spawner" pkg="gazebo_ros" type="spawn_model" respawn="false" output="screen"
          args="-urdf -model artmule_body -param robot_description"/>
      </launch>
This is the empty world file /artmulebody/world/emptyworld.world:
   <sdf version="1.5">
        <world name="default">
                <uri>model://sun</uri>
            <!-- A ground plane -->
            <physics type="ode">
            <max_step_size>0.001</max_step_size>
            <real_time_update_rate>1000</real_time_update_rate>
            <ode>
                <solver>
                <type>quick</type>
                <iters>51</iters>
                <sor>1.3</sor>
                <friction_model>pyramid_model</friction_model>
                </solver>
                <constraints>
                <cfm>0</cfm>
                <erp>0.2</erp>
                <contact_max_correcting_vel>100</contact_max_correcting_vel>
                <contact_surface_layer>0.001</contact_surface_layer>
                </constraints>
            </ode>
            </physics>
        </world>
The robot URDF file /artmulebody/urdf/artmulebody.urdf (note: this file was mostly generated by Solidworks, but I've added gazebo tags and some ode parameters and so on. The meshes are large and seem to display properly in gazebo (frame and wheels visuals). I adjusted the section to use a cylinder instead of a mesh because I thought this might be causing my wheel slip issue but it made no difference:
    <?xml version="1.0" encoding="utf-8"?>
<!-- This URDF was automatically created by SolidWorks to URDF Exporter! Originally created by Stephen Brawner (brawner@gmail.com)
    Commit Version: 1.5.1-0-g916b5db  Build Version: 1.5.7152.31018
    For more information, please see http://wiki.ros.org/sw_urdf_exporter -->
<robot name="artmule_body" xmlns:xacro="http://www.ros.org/wiki/xacro">
  <gazebo>
    <!--plugin name="gazebo_ros_wheel_slip" filename="libgazebo_ros_wheel_slip.so"-->
      <robotNamespace>/artmule_body</robotNamespace>
      <!--robotSimType>gazebo_ros_control/DefaultRobotHWSim</robotSimType-->
    <material>Gazebo/Grey</material>
  <gazebo reference="Lidar_Link">
    <material>Gazebo/White</material>
  <gazebo reference="Front_Link">
    <material>Gazebo/DarkGrey</material>
  <gazebo reference="Front_Left_Axle">
    <material>Gazebo/Black</material>
  <gazebo reference="Front_Right_Axle">
  <gazebo reference="Rear_Left_Axle">
  <gazebo reference="Rear_Right_Axle_Link">
  <gazebo reference="Front_Left_Wheel_Link">
    <material>Gazebo/Red</material>
    <collision>
  <gazebo reference="Front_Right_Wheel_Link">
    <material>Gazebo/FlatBlack</material>
    <collision>
  <gazebo reference="Rear_Left_Wheel_Link">
    <collision>
  <gazebo reference="Rear_Right_Wheel_Link">
    <collision>
  <pose>0.0 0.0 0.0 0.0 0.0 0.0</pose>
  <link name="base_link">
      <origin
        xyz="0.0 0.0 0.0"
        rpy="0 0 0" />
      <mass
        value="3" />
      <inertia
        ixx="0.001"
        ixy="0"
        ixz="0"
        iyy="0.001"
        iyz="0"
        izz="0.001" />
      <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/base_link.STL" />
      <material
        name="">
        <color
          rgba="0.792156862745098 0.819607843137255 0.933333333333333 1" />
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
  <link name="Lidar_Link">
      <origin
        xyz="0.0158797109484339 0.029853788807204 0.022237461889554"
        rpy="0 0 0" />
      <mass
        value="0.0772994590865252" />
      <inertia
        ixx="6.64800833992454E-05"
        ixy="-1.73920458974712E-06"
        ixz="-3.32295669660391E-06"
        iyy="5.81836937338085E-05"
        iyz="-5.34492302815605E-07"
        izz="3.62703552458512E-05" />
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/Lidar_Link.STL" />
      <material
        name="">
        <color
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
  <joint name="Lidar_Joint" type="continuous">
    <origin
      xyz="0 0 0.42396"
      rpy="1.5708 0 3.1416" />
    <parent
      link="base_link" />
    <child
      link="Lidar_Link" />
    <axis
      xyz="0 1 0" />
    <dynamics friction="0.1"/>
  <link name="Lidar_Tilt_Link">
      <origin
        xyz="8.07638090769945E-06 -0.00100548513406157 0.0116854584766925"
        rpy="0 0 0" />
      <mass
        value="0.046768032031124" />
      <inertia
        ixx="9.75790690949105E-06"
        ixy="2.61084698456655E-07"
        ixz="5.15965846181058E-08"
        iyy="2.10140566671905E-05"
        iyz="-1.09791527970008E-07"
        izz="1.80470043747733E-05" />
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/Lidar_Tilt_Link.STL" />
      <material
        name="">
        <color
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
  <joint name="Lidar_Tilt_Joint" type="continuous">
    <origin
      xyz="-0.002 0.040877 0"
      rpy="3.1416 -1.5708 0" />
    <parent
    <child
      link="Lidar_Tilt_Link" />
    <axis
      xyz="1 0 0" />
    <dynamics friction="1"/>
  <link name="Front_Pivot_Link">
      <origin
        xyz="-0.0237546791316809 4.74793554886817E-14 0.0694827387015425"
        rpy="0 0 0" />
      <mass
        value="0.526573475079648" />
      <inertia
        ixx="0.00081861339654528"
        ixy="3.0942087690996E-16"
        ixz="7.29485814683638E-16"
        iyy="0.00042749042229081"
        iyz="4.61802877737082E-09"
        izz="0.000409691525807351" />
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/Front_Pivot_Link.STL" />
      <material
        name="">
        <color
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
  <joint name="Front_Pivot_Joint" type="revolute">
    <origin
      xyz="0 0 0.191"
      rpy="0 0 -3.1416" />
    <parent
      link="base_link" />
    <child
      link="Front_Pivot_Link" />
    <axis
      xyz="0 0 1" />
    <limit lower="-0.50" upper="0.50" effort="0.0" velocity="0.1"/>
  <link name="Front_Link">
      <origin
        xyz="0.032210458084327 -2.44675140332228E-16 -0.00227904267394563"
        rpy="0 0 0" />
      <mass
        value="1.09953495959677" />
      <inertia
        ixx="0.00579621374440153"
        ixy="4.70295163512877E-18"
        ixz="0.000865002667992356"
        iyy="0.00275750881831944"
        iyz="7.28186718566E-18"
        izz="0.00580661102778322" />
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/Front_Link.STL" />
      <material
        name="">
        <color
          rgba="0.650980392156863 0.619607843137255 0.588235294117647 1" />
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
  <joint name="Front_Body_Joint" type="revolute">
    <origin
      xyz="-0.0299999999999996 0 0.0700000000000014"
      rpy="0 0 3.14159265358979" />
    <parent
    <child
      link="Front_Link" />
    <axis
      xyz="1 0 0" />
    <limit lower="-0.1" upper="0.1" effort="0.0" velocity="0.01"/>
  <link name="Front_Left_Axle">
      <origin
        xyz="3.88578058618805E-16 0.0272779029779359 0"
        rpy="0 0 0" />
      <mass
        value="0.0176819340805515" />
      <inertia
        ixx="2.26912683011394E-05"
        ixy="-1.76941275442854E-20"
        ixz="1.40141988769782E-35"
        iyy="5.18755491561235E-07"
        iyz="1.84609260716542E-20"
        izz="2.26912683011394E-05" />
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/Front_Left_Axle.STL" />
      <material
        name="">
        <color
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
  <joint name="Front_Left_Axle_Joint" type="fixed">
    <origin
      xyz="0.231999999999999 0.175000000000008 -0.0969999999999983"
      rpy="3.14159265358979 0 3.14159265358979" />
    <parent
    <child
      link="Front_Left_Axle" />
    <axis
      xyz="0 1 0" />
    Front left wheel LINK   <<<<
  <link name="Front_Left_Wheel_Link">
      <origin
        xyz="-0.0626072014447143 3.33066907387547E-16 -8.32667268468867E-17"
        rpy="0 0 0" />
      <mass
        value="3.92074665682532" />
      <inertia
        ixx="0.0592279373225076"
        ixy="-2.09783426676889E-17"
        ixz="2.63584046080219E-17"
        iyy="0.0316195974277248"
        iyz="-2.5321274476343E-17"
        izz="0.0316195974277248" />
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/Front_Left_Wheel_Link.STL" />
      <material
        name="">
        <color
          rgba="0.298039215686275 0.298039215686275 0.298039215686275 1" />
    <collision>
      <origin
        xyz="-0.06 0 0"
        rpy="-1.570810 0 -1.570810" />
        <!--mesh
          filename="package://artmule_body/meshes/Front_Left_Wheel_Link.STL" /-->
        <cylinder radius="0.162656352" length="0.06"/>
      <surface>
        <friction>
          <ode>
            <mu>0.01</mu>
            <mu2>0.01</mu2>
            <fdir1>1 0 0</fdir1>
            <slip1>0</slip1>
            <slip2>0</slip2>
          </ode>
        </friction>
      </surface>
  <joint name="Front_Left_Wheel_Joint" type="continuous">
    <origin
      xyz="0 0 0"
      rpy="0 0 -1.5707963267949" />
    <parent
    <child
      link="Front_Left_Wheel_Link" />
    <axis
      xyz="1 0 0" />
    <limit lower="-3.1419" upper="3.1419" effort="0.0" velocity="0.0"/>
  <link name="Front_Right_Axle">
      <origin
        xyz="3.33066907387547E-16 0.0652779029779602 -1.74860126378462E-15"
        rpy="0 0 0" />
      <mass
      <inertia
        ixy="-9.17944082682159E-23"
        ixz="3.24337094634816E-38"
        iyz="1.83930237390794E-20"
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/Front_Right_Axle.STL" />
      <material
        name="">
        <color
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
  <joint name="Front_Right_Axle_Joint" type="fixed">
    <origin
      xyz="0.231999999999999 -0.136999999999987 -0.0969999999999985"
    <parent
    <child
      link="Front_Right_Axle" />
    <axis
      xyz="0 1 0" />
    Front Right wheel LINK   >>>>
  <link name="Front_Right_Wheel_Link">
      <origin
        xyz="-0.0506072014447373 -5.55111512312578E-16 1.13797860024079E-15"
        rpy="0 0 0" />
      <mass
        value="3.92074665682533" />
      <inertia
        ixy="1.71725648798771E-17"
        ixz="1.9354269196565E-16"
        iyz="-1.74508722187149E-17"
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/Front_Right_Wheel_Link.STL" />
      <material
        name="">
        <color
    <collision>
      <origin
        xyz="-0.06 0 0"
        <!--mesh
          filename="package://artmule_body/meshes/Front_Right_Wheel_Link.STL" /-->
      <surface>
        <friction>
          <ode>
            <mu>0.01</mu>
            <mu2>0.01</mu2>
            <slip1>0</slip1>
            <slip2>0</slip2>
          </ode>
        </friction>
      </surface>
  <joint name="Front_Right_Wheel_Joint" type="continuous">
    <origin
      xyz="0 0.05 0"
      rpy="3.14159265358979 0 -1.5707963267949" />
    <parent
    <child
      link="Front_Right_Wheel_Link" />
    <axis
      xyz="1 0 0" />
  <link name="Rear_Left_Axle">
      <origin
        xyz="5.3089199703038E-12 0.065277902977945 -1.97064586870965E-15"
        rpy="0 0 0" />
      <mass
      <inertia
        ixy="-1.80344567611677E-15"
        ixz="-1.5979906930206E-30"
        iyy="5.18755491561233E-07"
        iyz="-1.9675556218577E-20"
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/Rear_Left_Axle.STL" />
      <material
        name="">
        <color
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
  <joint name="Rear_Left_Axle_Joint" type="fixed">
    <origin
      xyz="-0.261 0.1495 0.164"
      rpy="0 0 0" />
    <parent
      link="base_link" />
    <child
      link="Rear_Left_Axle" />
    <axis
      xyz="0 1 0" />
    Rear Left wheel LINK   <<<<
  <link name="Rear_Left_Wheel_Link">
      <origin
        xyz="-0.0506072014447241 -4.11615186379777E-12 1.11022302462516E-16"
        rpy="0 0 0" />
      <mass
      <inertia
        ixy="2.24556942797003E-12"
        ixz="-4.33805306771177E-17"
        iyz="-7.77034648905791E-18"
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/Rear_Left_Wheel_Link.STL" />
      <material
        name="">
        <color
    <collision>
      <origin
        xyz="-0.06 0 0"
        <!--mesh
          filename="package://artmule_body/meshes/Rear_Left_Wheel_Link.STL" /-->
      <surface>
        <friction>
          <ode>
            <mu>0.01</mu>
            <mu2>0.01</mu2>
            <slip1>0</slip1>
            <slip2>0</slip2>
          </ode>
        </friction>
      </surface>
  <joint name="Rear_Left_Wheel_Joint" type="continuous">
    <origin
      xyz="0 0.05 0"
    <parent
    <child
      link="Rear_Left_Wheel_Link" />
    <axis
      xyz="1 0 0" />
  <link name="Rear_Right_Axle_Link">
      <origin
        xyz="5.30947508181612E-12 0.0652779029779457 -2.77555756156289E-17"
        rpy="0 0 0" />
      <mass
      <inertia
        ixz="5.74555439277144E-31"
        iyy="5.18755491561234E-07"
        iyz="6.96153122075381E-21"
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/Rear_Right_Axle_Link.STL" />
      <material
        name="">
        <color
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
  <joint name="Rear_Right_Axle_Joint" type="fixed">
    <origin
      xyz="-0.26100000001216 -0.14949999997877 0.164000000000002"
    <parent
      link="base_link" />
    <child
      link="Rear_Right_Axle_Link" />
    <axis
      xyz="0 1 0" />
    Rear Right wheel LINK   >>>>
  <link name="Rear_Right_Wheel_Link">
      <origin
        xyz="-0.0506072014447241 -4.116207374949E-12 5.55111512312578E-17"
        rpy="0 0 0" />
      <mass
      <inertia
        ixy="2.24557145887076E-12"
        ixz="-5.95978435637949E-18"
        iyz="-4.63148764679093E-18"
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://artmule_body/meshes/Rear_Right_Wheel_Link.STL" />
      <material
        name="">
        <color
    <collision>
      <origin
        xyz="-0.06 0 0"
        <!--mesh
          filename="package://artmule_body/meshes/Rear_Right_Wheel_Link.STL" /-->
      <surface>
        <friction>
          <ode>
            <mu>0.01</mu>
            <mu2>0.01</mu2>
            <slip1>0</slip1>
            <slip2>0</slip2>
          </ode>
        </friction>
      </surface>
  <joint name="Rear_Right_Wheel_Joint" type="continuous">
    <origin
      xyz="0 0.05 0"
    <parent
    <child
      link="Rear_Right_Wheel_Link" />
    <axis
      xyz="1 0 0" />
  <transmission name="lidar_tilt_trans">
    <joint name="Lidar_Tilt_Joint">
      <hardwareInterface>hardware_interface/PositionJointInterface</hardwareInterface>
    <actuator name="lidar_tilt">
    </actuator>
  </transmission>
  <transmission name="lidar_trans">
    <joint name="Lidar_Joint">
    <actuator name="lidar_rotate">
    </actuator>
  </transmission>
  <transmission name="centre_steering_trans">
    <joint name="Front_Pivot_Joint">
    <actuator name="steering_actuator">
    </actuator>
  </transmission>
  <transmission name="front_left_wheel_trans">
    <joint name="Front_Left_Wheel_Joint">
      <hardwareInterface>hardware_interface/EffortJointInterface</hardwareInterface>
    <actuator name="wheel_actuator">
    </actuator>
  </transmission>
</robot>
I have a robot control node using controller manager /artmulecontrol/launch/artmulecontrol.launch:
    <launch>
  <!-- Load joint controller configurations from YAML file to parameter server -->
  <rosparam file="$(find artmule_control)/config/artmule_control.yaml" command="load"/>
  <!-- load the controllers -->
  <node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
    output="screen" ns="/artmule_body" args="lidar_position_controller lidar_tilt_position_controller fpj_position_controller joint_state_controller"/>
  <!-- convert joint states to TF transforms for rviz, etc -->
    <remap from="/joint_states" to="/artmule_body/joint_states" />
  </node>
</launch>
And its yaml config file /artmulecontrol/config/artmulecontrol.yaml:
    artmule_body:
  # Publish all joint states -----------------------------------
  joint_state_controller:
    type: joint_state_controller/JointStateController
    publish_rate: 50
  # Position Controllers ---------------------------------------
  lidar_position_controller:
    type: position_controllers/JointPositionController
    joint: Lidar_Joint
    pid: {p: 5.0, i: 0.01, d: 0.1}
  lidar_tilt_position_controller:
    joint: Lidar_Tilt_Joint
  fpj_position_controller:
    joint: Front_Pivot_Joint
    pid: {p: 5.01, i: 0.001, d: 0.001}
  # Velocity Controllers
  flw_velocity_controller:
    type: effort_controllers/JointVelocityController
    joint: Front_Left_Wheel_Joint
Asked by zonared on 2023-04-22 02:00:37 UTC
