How can I initialize the joint position of a revolue2 joint?
Hello, I encounter some problems when I try to initialize the joint position of a revolue2 joint.
I use the -J parameter of 'spawn_model' node in the launch file to set the specified joint to a wanted position.
The problem is: the joint type was 'revolute2', so I can not figure out how to specify the position of each DoF of the joint. I've tried script like<node pkg="gazebo_ros" type="spawn_model" name="model" args="-sdf -model pendulum -param robot_description -J base_link2link_link 0.1 0.1" />
, but that doesn't work.
The definition of my joint in the .sdf file is like:
<joint name='base_link2link_link' type='revolute2'>
<pose relative_to='base_link'>0 0 0 0 -0 0</pose>
<parent>base_link</parent>
<child>link_link</child>
<axis>
<xyz>1 0 0</xyz>
<limit>
<lower>-1e+16</lower>
<upper>1e+16</upper>
</limit>
</axis>
<axis2>
<xyz>0 1 0</xyz>
<limit>
</limit>
</axis2>
Asked by Fran on 2023-04-23 09:00:14 UTC
