max_step_size vs sensor update_rate
I run gazebo 11.10.2 with the option --lockstep and a robot with a ray sensor (laser scanner) that I would like to run at update_rate of 400 Hz
The world's physics is set to realtimeupdate_rate =1000 Hz and maxstepsize=1 ms / step
This means the sensor expects a period between OnUpdate calls to be 2.5 ms, which cannot be reached with a 1 ms resolution of the gazebo physics update. At best the sensor OnUpdate is called at 3 ms, which means 333 Hz update rate. I am fine with that obvious limit.
So to work-around the limit, I set my realtimeupdate_rate=400 Hz and maxstepsize=2.5 ms / step so that the physics update and sensor update occur in sync (also permits to have other sensors at 100 Hz without issues), but in that setup, the sensor update that should be 400 Hz reaches 200 Hz at best.
Is there something wrong with my logic ?
To me it looks as if some time computation was wrongly computed when the time that passed is exactly the expected period.
Asked by GuiHome on 2023-04-24 04:30:05 UTC
