Gazebo Fortress Parameter bridge not working
I am trying to launch my custom robot urdf ion Gazebo Fortress but the "parameter bridge" is not working and I am not able to echo or publish to any topics.
here is my urdf file which also contains ignition gazebo plugins testrobotign.xacro
I first launch the robot_description.launch.py which contains the robot state publisher and joint state publisher.
After that, I launch the ignition.launch.py which - launches the igngazebo.launch.py file from rosigngazebo with a custom world sdf file - spawns the robot by running create node from rosigngazebo by subscribing the robotdescription topic - runs the parameterbridge from rosign_bridge
I am able to successfully see my robot and the custom sdf world file in gazebo Fortress but I am not able to control the robot using teleop.
I am only running the parameter bridge for /cmd_vel topic. image description
Even if I am not running the teleop node, I get 1 subscription count and 1 publisher count for /cmd_vel topic image description
I am getting the following rqt_graph rqt_graph
Asked by nilutpolkashyap on 2023-06-02 02:04:41 UTC
