Gazebo Kinect Plugin Point Transformation for RayShape
Hello, I'm trying to simulate a stackingbox with some elements and create a PointCloud with the kinect camera and now im trying to label these points with the ids of the elements with an rayshape
The cam is at "0.0 0.0 1.9 0.0 1.5707963267948966 0.0" so i tried to transfrom the frame with <node pkg="tf2_ros" type="static_transform_publisher" name="world_broadcaster" args="0.0 0.0 1.9 0.0 1.5707963267948966 0.0 map depth_camera_link" />
but than the map frame is not at (0,0,0) https://ibb.co/0fFwHc1
when I use
-1.9 0.00000, 0.00000, 0.00000, 1.00000 map depth_camera_link" />
https://ibb.co/XxfLSD6
Then it is in the middle of the stackingbox where also the root point of the world is
But unfortunately the ray laser is not completely correct (https://ibb.co/JjCgZJw)
I use in these example a banana as an element
My Source code: https://github.com/kingingo/BinPickingSim
Asked by felixoben on 2023-06-02 08:37:34 UTC
