Robot model not shown properly in Gazebo
Hi Developers, I am struggling for days to spawn a Baxter robot, which URDF file I got from here in Gazebo. Using RViz the robot gets properly spawned. To spawn the robot I am using a launch file in ROS2 Foxy. The relevant part is this one:
# Subscribes to the joint states of the robot, and publishes the 3D pose of each link.
robot_state_publisher_node = Node(
condition=UnlessCondition(use_rviz),
package='robot_state_publisher',
executable='robot_state_publisher',
output='screen',
parameters=[{'use_sim_time': use_sim_time}],
arguments=[robot_description_file]
# Publishes the joint state values for the non-fixed joints in the URDF file.
joint_state_publisher_node = Node(
package='joint_state_publisher',
executable='joint_state_publisher',
name='joint_state_publisher')
# Spawnes the robot at a given position and with a specific pose
spawn_entity = Node(
package='gazebo_ros',
executable='spawn_entity.py',
arguments=['-entity', robot_model_name,
'-topic', '/robot_description',
'-x', position_x, '-y', position_y, '-z', position_z,
'-R', orientation_R, '-P', orientation_P, '-Y', orientation_Y, 'file', robot_description_file],
output='screen')
I have attached a screenshot to show that in Gazebo only some parts get displayed. I have tried to set the GAZEBORESOURCEPATH, but every time I start the launch file, I get this error message:
[ERROR] [spawnentity.py-5]: process has died [pid 42722, exit code 2, cmd '/opt/ros/foxy/lib/gazeboros/spawnentity.py -entity baxter -topic /robotdescription -x 0.0 -y 0.0 -z 0.0 -R 0.0 -P 0.0 -Y -1.57 file ...baxter.urdf --ros-args'
After searching the internet I found that Gazebo has to know about the .dae mesh file to display them. I have also tested this solution, but nothing changed.
I hope someone can provide help, because I am struggling for days as mentioned before.
Asked by mike on 2023-06-21 15:02:21 UTC
