Fatal error when loading heightmap : Assertion failed
Hi! I'm trying to load a heightmap into gazebo garden. I haven't encountered this error with previous heigthmaps of different dimensions, so I'm wondering if someone would know what the error means and how it can be fixed. Thanks!
Setup :
- Ubuntu 20.04
- Gazebo Garden
- .IMG heightmap from https://www.uahirise.org/dtm/ESP_016845_1715 converted to .tif using
gdal_translate -of GTIFFas recommended and placed in models/map_marsHiLabyrinth/dem/labyrinth.tif
Code to replicate :
models/map_marsHiLabyrinth/model.sdf
<?xml version="1.0" ?>
<sdf version="1.7">
<model name="labyrinth">
<heightmap>
<uri>dem/labyrinth.tif</uri>
<size>5317 11578 2</size>
<pos>0 0 0</pos>
</heightmap>
worlds/labyrinth.sdf
<sdf version="1.7">
<world name="labyrinth">
<!-- PLUGINS -->
filename="gz-sim-physics-system"
name="gz::sim::systems::Physics">
filename="gz-sim-scene-broadcaster-system"
name="gz::sim::systems::SceneBroadcaster">
filename="gz-sim-user-commands-system"
name="gz::sim::systems::UserCommands">
<!-- PHYSICS -->
<physics name="1ms" type="ignored">
<max_step_size>0.001</max_step_size>
<real_time_factor>1.0</real_time_factor>
</physics>
<gravity>0 0 -9.8</gravity>
<!-- TERRAIN -->
<spherical_coordinates>
<surface_model>CUSTOM_SURFACE</surface_model>
<world_frame_orientation>ENU</world_frame_orientation>
<latitude_deg>-5.0</latitude_deg>
<longitude_deg>267.81</longitude_deg>
<elevation>0</elevation>
<heading_deg>0</heading_deg>
<surface_axis_equatorial>3396190</surface_axis_equatorial>
<surface_axis_polar>3376200</surface_axis_polar>
</spherical_coordinates>
<include><uri>model://map_marsHiLabyrinth</uri></include>
<!-- GUI -->
<gui fullscreen='false'>
<plugin name='3D View' filename='GzScene3D'>
<gz-gui>
<title>3D View</title>
<property type='bool' key='showTitleBar'>0</property>
<property type='string' key='state'>docked</property>
</gz-gui>
<engine>ogre2</engine>
<scene>scene</scene>
</gui>
</world>
Error :
$ gz sim labyrinth.sdf
[Err] [SDFFeatures.cc:843] The geometry element of collision [collision] couldn't be created
libEGL warning: DRI2: failed to create dri screen
gz sim gui: /home/jenkins/workspace/gz-rendering7-debbuilder/build/gz-rendering-7.4.0/ogre2/src/terrain/Terra/src/TerraShadowMapper.cpp:281: void Ogre::ShadowMapper::updateShadowMap(const Ogre::Vector3&, const Ogre::Vector2&, float): Assertion `m_shadowStarts->getNumElements() >= (m_heightMapTex->getHeight() << 4u)' failed.
Stack trace (most recent call last) in thread 138111:
#29 Object "[0xffffffffffffffff]", at 0xffffffffffffffff, in
#28 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f49bce88132, in clone
#27 Object "/lib/x86_64-linux-gnu/libpthread.so.0", at 0x7f49bcd4e608, in
#26 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7f49b73f89d1, in
#25 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7f49b73f7784, in QThread::exec()
#24 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7f49b75bf3aa, in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)
#23 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7f49b7618434, in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#22 Object "/lib/x86_64-linux-gnu/libglib-2.0.so.0", at 0x7f49b53d14a2, in g_main_context_iteration
#21 Object "/lib/x86_64-linux-gnu/libglib-2.0.so.0", at 0x7f49b53d13ff, in
#20 Object "/lib/x86_64-linux-gnu/libglib-2.0.so.0", at 0x7f49b53d117c, in g_main_context_dispatch
#19 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7f49b7618e36, in
#18 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7f49b75c3487, in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*)
#17 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7f49b75c0809, in QCoreApplication::notifyInternal2(QObject*, QEvent*)
#16 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7f49b6d5f0ef, in QApplication::notify(QObject*, QEvent*)
#15 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7f49b6d55a65, in QApplicationPrivate::notify_helper(QObject*, QEvent*)
#14 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7f49b75ecc29, in QObject::event(QEvent*)
#13 Object "/usr/lib/x86_64-linux-gnu/gz-gui-7/plugins/libMinimalScene.so", at 0x7f49a12c98a8, in
gz::gui::plugins::RenderThread::RenderNext(gz::gui::plugins::RenderSync*)
#12 Object "/usr/lib/x86_64-linux-gnu/gz-gui-7/plugins/libMinimalScene.so", at 0x7f49a12daad7, in gz::gui::plugins::RenderThreadRhiOpenGL::RenderNext(gz::gui::plugins::RenderSync*)
#11 Object "/usr/lib/x86_64-linux-gnu/gz-gui-7/plugins/libMinimalScene.so", at 0x7f49a12d213b, in gz::gui::plugins::GzRenderer::Render(gz::gui::plugins::RenderSync*)
#10 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f496f21ec7d, in gz::rendering::v7::BaseCamera<gz::rendering::v7::Ogre2Sensor>::Update()
#9 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f496f2bde24, in gz::rendering::v7::Ogre2RenderTarget::Render()
#8 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f496f2c64e6, in gz::rendering::v7::Ogre2Scene::StartRendering(Ogre::Camera*)
#7 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f496f2c61d7, in gz::rendering::v7::Ogre2Scene::UpdateAllHeightmaps(Ogre::Camera*)
#6 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f496f259ec7, in gz::rendering::v7::Ogre2Heightmap::UpdateForRender(Ogre::Camera*)
#5 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f496f2f3d3c, in Ogre::Terra::update(Ogre::Vector3 const&, float)
#4 Object "/usr/lib/x86_64-linux-gnu/gz-rendering-7/engine-plugins/libgz-rendering-ogre2.so", at 0x7f496f2f7c24, in Ogre::ShadowMapper::updateShadowMap(Ogre::Vector3 const&, Ogre::Vector2 const&, float)
#3 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f49bcd9cfd5, in __assert_fail
#2 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f49bcd8b728, in
#1 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f49bcd8b858, in abort
#0 Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f49bcdac00b, in gsignal
Aborted (Signal sent by tkill() 138020 1000)
Asked by tanguy on 2023-07-07 13:09:25 UTC
