[ROS gz project template] Invalid frame ID passed to canTransform
I'm getting these warnings in the terminal, running the ROS gz project template. Simulation works just fine, so why does these warnings show, and how can I fix the problems?
[rviz2-4] Warning: Invalid frame ID "diff_drive/chassis" passed to canTransform
argument source_frame - frame does not exist
[rviz2-4] at line 93 in ./src/buffer_core.cpp
[rviz2-4] Warning: Invalid frame ID "diff_drive/lidar_link" passed to canTransform
Here is a screenshot from RViz, displaying the
and here is the "frame tree" from ros2 run tf2_tools view_frames
So basically the error complains that the frames under the "chassis" frame, are not connected the diff_drive/odom frame, just as shown in the tree. This corresponds with the links defined in the model.sdf in the description package, imported by the Gazebo example package in diff_drive.sdf.
Somehow a collection of the links in the included SDF file, are duplicated outside of the diff_drive/odom tree.
<include merge="true">
<uri>package://ros_gz_example_description/models/diff_drive</uri>
I notice that the models in the model.sdf file and diff_drive.sdf file has the same model name (diff_drive). Can that be a source of misbehavior?
Asked by Simple Simpson on 2023-07-12 07:43:42 UTC
