How to create plain color walls from a greyscale image
I want to create a simple office-like environment from an image. One possibility would be to create it using heightmaps, but I was not able to do so with only a single texture or plain color (the examples I could find all use three textures...).
Another more obvious option, since I only have 1 height, is to use the "image" option. However I have not been successful with my various tries. I am using ros fuerte with the gazebo that comes with it.
You can find below the latest environment I tested:
<gazebo version='1.0'>
  <world name='default'>
    <scene>
      <ambient rgba='0.1 0.1 0.1 1.0'/>
      <background rgba='0.7 0.7 0.7 1.0'>
        <sky material='Gazebo/CloudySky'/>
      </background>
      <shadows enabled='1'/>
    </scene>
    <physics type='ode' update_rate='0.0'>
      <gravity xyz='0.0 0.0 -9.8'/>
      <ode>
        <solver type='quick' dt='0.001000' iters='50' precon_iters='0' sor='1.3'/>
        <constraints cfm='0.0' erp='0.1' contact_max_correcting_vel='100.0' contact_surface_layer='0.001000'/>
      </ode>
    </physics>
    <!-- Ground Plane -->
    <model name='plane1_model' static='1'>
      <link name='body'>
        <collision name='geom_1'>
            <plane normal='0 0 1'/>
          <surface>
            <friction>
              <ode mu='10.0' mu2='10.0' fdir1='0 0 0' slip1='0' slip2='0'/>
            </friction>
            <bounce restitution_coefficient='0' threshold='1000000.0'/>
            <contact>
              <ode soft_cfm='0' soft_erp='0.2' kp='1e10' kd='1' max_vel='100.0' min_depth='0.0001'/>
            </contact>
          </surface>
        <visual name='visual_1' cast_shadows='0'>
          <material script='Gazebo/White'>
            <emissive rgba='1.0 1.0 1.0 1.0'/>
    <model name='map' static='1'>
      <link name='link' gravity='1' self_collide='0' kinematic='0'>
        <origin pose='0.0 0.0 0.0 0.0 -0.0 0.0'/>
        <collision name='collision' laser_retro='0.0'>
             <image filename='willowMap.png' scale='100' threshold ='200' height='1.0' granularity='1'/>
        <visual name='visual' cast_shadows='1' laser_retro='0.0' transparency='0.0'>
          <material />
        <damping/>
    <model name='table1' static='1'>
      <origin pose='2.0 3.0 -0.010 0.0 0.0 -1.570800'/>
      <link name='body' gravity='1' self_collide='0' kinematic='0'>
        <collision name='top' laser_retro='0.0'>
          <origin pose='0.0 0.0 0.620 0.0 -0.0 0.0'/>
            <box size='1.4 0.5 0.050000'/>
          <surface>
            <friction>
              <ode mu='-1.0' mu2='-1.0' fdir1='0.0 0.0 0.0' slip1='0.0' slip2='0.0'/>
            </friction>
            <bounce restitution_coefficient='0.0' threshold='100000.0'/>
            <contact>
              <ode soft_cfm='0.0' soft_erp='0.2' kp='1000000000000.0' kd='1.0' max_vel='100.0' min_depth='0.001000'/>
            </contact>
          </surface>
        <visual name='top_visual' cast_shadows='1' laser_retro='0.0' transparency='0.0'>
          <origin pose='0.0 0.0 0.010 0.0 -0.0 0.0'/>
            <mesh filename='table.dae' scale='1.0 1.0 1.0'/>
        <damping/>
    <light name='directional' type='directional' cast_shadows='0'>
      <origin pose='0.0 0.0 100.0 0.0 -0.0 0.0'/>
      <diffuse rgba='1.0 1.0 1.0 1.0'/>
      <specular rgba='0.10 0.10 0.10 1.0'/>
      <attenuation range='200.0' linear='0.010000' constant='0.500000' quadratic='0.001000'/>
      <direction xyz='0.010 0.0 -0.990000'/>
    </light>
  </world>
Asked by Hugo Costelha on 2013-05-24 10:11:56 UTC
Use the UV texture image as your image file. It is used especially for for textures. you can look here as an example to create texture for your office.
http://www.jawa9000.com/Technical/UVs/UVs.htm
Asked by Bharath on 2014-07-02 04:28:41 UTC
The link is unavailable
Asked by Hugo Costelha on 2015-03-26 09:10:43 UTC
From Gazebo 5.0, you can use the Building Editor to trace over a floor plan image to create walls, windows, doors and so on.
Asked by chapulina on 2015-03-26 15:55:13 UTC
I was trying to do it with Gazebo which "comes with ROS Indigo". I will test the Building Editor as soon as I can switch to Gazebo >= 5.0
Asked by Hugo Costelha on 2015-04-01 10:34:43 UTC
