Error attempting to launch Cloudsim
asked 2013-05-29 15:50:35 -0500
Nick Eckenstein gravatar image
I am attempting to launch a basic CloudSim instance. I follow the tutorial here: http://gazebosim.org/wiki/Tutorials/CloudSim/setup
But when I get to the following step (actually starting the instance), I get an error I cannot solve. Specifically, I type:
./cloudsim-1.5.0/bin/create_cloudsim.py EMAIL ACCESSKEY SECRETKEY us-east-1a
Where EMAIL, ACCESSKEY, and SECRETKEY are my credentials, as appropriate. The output I get is the following: (my email replaced by EMAIL)
launch_db> c40e527fc/username = EMAIL
launch_db> c40e527fc/constellation_name = c40e527fc
launch_db> c40e527fc/gmt = 2013-05-29 20:35:08
launch_db> c40e527fc/configuration = cloudsim
launch_db> c40e527fc/constellation_directory = /tmp/tmph8ZJx1cloudsim
launch_db> c40e527fc/constellation_state = launching
launch_db> c40e527fc/error =
  File "./cloudsim-1.5.0/bin/create_cloudsim.py", line 50, in <module>
    machine = cloudsim.cloudsim_bootstrap(username, tmp_fname.name, auto_launch_constellation)
  File "/home/modlabvis5/custom_worlds/cloudsim-1.5.0/cloudsimd/launchers/cloudsim.py", line 538,
in cloudsim_bootstrap
    constellation_directory, website_distribution)
  File "/home/modlabvis5/custom_worlds/cloudsim-1.5.0/cloudsimd/launchers/cloudsim.py", line 245,
in launch
    cfg = get_cloudsim_config()
1.5.0/cloudsimd/launchers/launch_utils/launch_db.py", line 247, in get_cloudsim_config
    config = json.loads(s)
  File "/usr/lib/python2.7/json/__init__.py", line 328, in loads
    return _default_decoder.decode(s)
  File "/usr/lib/python2.7/json/decoder.py", line 365, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
TypeError: expected string or buffer
I've got all the expected arguments: (email, both keys, and the zone), so I cannot determine what string might be missing. Really no idea what's going on here; any help would be appreciated.
Thanks.
answered 2013-06-01 14:15:07 -0500
Carlos Agüero gravatar image
updated 2013-06-01 14:18:01 -0500
Those tutorials were created for using CloudSim with Amazon Web Services. The current version of CloudSim only works with SoftLayer cloud provider. If you are using CloudSim for the DARPA VRC, read the VRC User Guide for detailed instructions of how to use the latest version of CloudSim with SoftLayer.
As Pedro suggested, 1.4.0 should work with Amazon.
answered 2013-06-01 12:14:13 -0500
PedroMadrid gravatar image
Hello Nick!. I had the same problem, and, how I solved it is installing cloudsim-1.4.0. For me seem to be that tutorials are wrong. Actually Amazon AWS had been changed by SoftLayer. I think that's the problem in CloudSim > 1.4. And as you can see what fails is a JSON decoding. What means that some kind of communication to host (SoftLayer whit amazon's credentials) had failed... Well but that last is just a theory. I hope this helps.
Asked: 2013-05-29 15:50:35 -0500
Seen: 191 times
Last updated: Jun 01 '13
