gazebo1.8+drcsim2.6 fails starting
using: drcsim 2.6 + gazebo 1.8.2
After we followed the given instructions in DRC install ... When starting >> roslaunch atlas_utils atlas.launch << this start fails like follows:
... logging to /home/everybody/.ros/log/37d7cb22-c85b-11e2-92b5-b4b52fc222cb/roslaunch-RitterROSt-26220.log
Press Ctrl-C to interrupt
started roslaunch server http://RitterROSt:55592/
SUMMARY
PARAMETERS
 * /atlas/delay_max_per_step
 * /atlas/delay_max_per_window
 * /atlas/delay_window_size
 * /atlas/time_to_unpin
 * /atlas_controller/gains/back_lbz/d
 * /atlas_controller/gains/back_lbz/i
 * /atlas_controller/gains/back_lbz/i_clamp
 * /atlas_controller/gains/back_lbz/p
  .... snipppp .....
 * /use_sim_time
NODES
  /multisense_sl/camera/
    stereo_proc (stereo_image_proc/stereo_image_proc)
    atlas_robot_state_publisher (robot_state_publisher/state_publisher)
    gazebo (atlas_utils/run_gazebo)
    multisense_sl_robot_state_publisher (robot_state_publisher/state_publisher)
    tf2_buffer_server (tf2_ros/buffer_server)
core service [/rosout] found
process[gazebo-1]: started with pid [26238]
process[atlas_robot_state_publisher-2]: started with pid [26245]
process[multisense_sl_robot_state_publisher-3]: started with pid [26266]
process[tf2_buffer_server-4]: started with pid [26286]
process[multisense_sl/camera/stereo_proc-5]: started with pid [26329]
Error [ConnectionManager.cc:88] Connection Manager is not running
[gazebo-1] process has finished cleanly
Showing us that connection manager could not start propperly. We cannot find the reason for that.
When starting >>gazebo gazebo_ros_depth_camera.world<<
this starts successfully as long as we do not source /usr/share/drcsim/setup.sh
When we souce that file also our plain (w/o drcsim) gazebo fails starting.
The drcsim-ros-nodes seem to have started without errors. What can we do to get drcsim up and running?
Thanks in advance
--jens
Edit:
Starting >>gazebo gazebo_ros_depth_camera.world<<
with source /usr/share/drcsim/setup.sh
Gazebo itself starts, but the plugin doesn't start while the plugin runs properly w/o source /usr/share/drcsim/setup.sh
everybody@RitterROSt:~/catkin_ws/src/gazebo_pkgs/gazebo_plugins/test/test_worlds$ source /usr/share/drcsim/setup.sh
everybody@RitterROSt:~/catkin_ws/src/gazebo_pkgs/gazebo_plugins/test/test_worlds$ gazebo gazebo_ros_depth_camera.world
Gazebo multi-robot simulator, version 1.8.2
Copyright (C) 2013 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for master.Warning [parser.cc:361] Converting a deprecated SDF source[/home/everybody/catkin_ws/src/gazebo_pkgs/gazebo_plugins/test/test_worlds/gazebo_ros_depth_camera.world].
Warning [Converter.cc:58]   Version[1.3] to Version[1.4]
  Please use the gzsdf tool to update your SDF files.
    $ gzsdf convert [sdf_file]
Warning [parser.cc:499] XML Attribute[near] in element[clip] not defined in SDF, ignoring.
Warning [parser.cc:499] XML Attribute[far] in element[clip] not defined in SDF, ignoring.
Warning [parser.cc:499] XML Attribute[path] in element[save] not defined in SDF, ignoring.
Warning [parser.cc:499] XML Attribute[output] in element[depth_camera] not defined in SDF, ignoring.
Msg Publicized address: 172.17.240.130
Warning [ODEPhysics.cc:204] Gravity vector is (0, 0, 0). Objects will float.
Error [Plugin.hh:126] Failed to load plugin libgazebo_ros_depth_camera.so: libgazebo_ros_depth_camera.so: cannot open shared object file: No such file or directory
Error [Param.hh:249] Unable to set value [1,0471975511965976] for key[horizontal_fov]
Error [Param.hh:249] Unable to set value [0,100000001] for key[near]
Asked by jens.lauer on 2013-05-30 10:47:23 UTC
What happens if you do source /usr/share/drcsim/setup.sh and then try to run gazebo? What does the failure look like?
Asked by gerkey on 2013-05-30 23:18:06 UTC
@gerky Edit in first post.
Asked by jens.lauer on 2013-05-31 02:37:37 UTC
About Error [Param.hh:249].. : My system is in French. I have added LC_NUMERIC=en_US.UTF-8 to /etc/default/locale and now those errors do not show.
Asked by jojolalpin on 2013-06-01 03:27:18 UTC
Please reopen if this is still active in the latest releases.
Asked by Jose Luis Rivero on 2014-04-30 11:23:02 UTC
