How can I open DRC simulator 2.6 without Errors?
asked 2013-05-30 19:32:02 -0500
Jey_316 gravatar image
I have installed ROS groovy on Ubuntu 12.10, 64 bits.
I have also installed drcsim 2.6 with "Compiling from source" tutorial.
The problem is:
-WHen I tried to open the ATLAS robot model with:
. /usr/local/share/drcsim/setup.sh
roslaunch atlas_utils atlas.launch
-I get the following errors:
Setting /run_id to e1eda8dc-c984-11e2-8837-003067bb0d9a
process[rosout-1]: started with pid [4369]
gazebo: error while loading shared libraries: libgazebo_common.so.1: cannot open shared object
file: No such file or directory
failed to start local process: /usr/local/share/drcsim-2.6/ros/atlasutils/scripts/rungazebo atlas.world -q _name:=gazebo _log:=/home/john/.ros/log/e1eda8dc-c984-11e2-8837-003067bb0d9a/gazebo-2.log local launch of atlasutils/rungazebo failed [gazebo-2] process has died [pid -1, exit code 127, cmd /usr/local/share/drcsim-2.6/ros/atlasutils/scripts/rungazebo atlas.world -q _name:=gazebo _log:=/home/john/.ros/log/e1eda8dc-c984-11e2-8837-003067bb0d9a/gazebo-2.log]. log file: /home/john/.ros/log/e1eda8dc-c984-11e2-8837-003067bb0d9a/gazebo-2*.log
How can I solve this problem?
answered 2013-05-30 21:22:43 -0500
gerkey gravatar image
Looks like your loader is not looking for libraries /usr/local/lib. Two options:
  1. Set LD_LIBRARY_PATH:
    export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
  2. Configure your system to always look in /usr/local/lib. Start by looking in /etc/ld.so.conf.
You'll know that it works when this command gives no output:
ldd `which gazebo` | grep "not found"
I chose the option number 1. And now I get a different error:
Error [Param.hh:249] Unable to set value [1,0471975511965976] for key[horizontal_fov]
Error [Param.hh:249] Unable to set value [0,100000001] for key[near]
[gazebo-2] process has finished cleanly
log file: /home/john/.ros/log/c0b21dfa-cc73-11e2-8bc9-003067bb0d9a/gazebo-2*.log
Jey_316 gravatar imageJey_316 ( 2013-06-03 12:31:49 -0500 )edit
That looks like a locale issue (error interpreting commas as decimal separators). Try setting `LANG="C"` or `LANG="en_US"`.
gerkey gravatar imagegerkey ( 2013-06-03 14:37:36 -0500 )edit
Asked: 2013-05-30 19:32:02 -0500
Seen: 309 times
Last updated: May 30 '13
