I using the gazebo 1.8.6 with ROS Groovy, but not load the spawn_model in the rxgraph.
Hi, I need some help to create my robot. My problem is publish the spawnmodel. I can't load the spawnmodel in the rxgraph, it appears and disappears soon after.
Asked by EduardoMaciel on 2013-06-24 14:10:33 UTC
I made this documentation that might help, although technically its for Gazebo 1.9 (unreleased) and the new gazebo_ros_pkgs, it is mostly the same for 1.8.6:
http://gazebosim.org/wiki/Tutorials/1.9/Using_roslaunch_Files_to_Spawn_Models
Asked by davetcoleman on 2013-06-24 17:17:39 UTC
Hi dave, I followed your tutorial, but I have a problem. When launching the command (roslaunch baxter_gazebo baxter_world.launch) initializes the gazebo, but it presents the following error: (Warning [parser.cc: 314] parse from urdf.). Using rxgraph can see that SpawnModel does not load, do you know what can be?
Asked by EduardoMaciel on 2013-06-25 08:50:59 UTC
First, I believe you are using an older version of Gazebo. How did you install it? You should install it from source, for now, as described in http://gazebosim.org/wiki/Tutorials/1.9/Installing_gazebo_ros_Packages
Asked by davetcoleman on 2013-06-25 16:04:54 UTC
Asked by davetcoleman on 2013-06-25 16:05:24 UTC
I reinstalled the Gazebo how describes the link (Compiling From Source / Download via Mercurial - hg clone https://bitbucket.org/osrf/gazebo gazebo and Compile Instructions - http://gazebosim.org/wiki/1.6/install # Compile_Instructions). When the gazebo is booting, he describes the version 1.8.6, is this the correct version?
Gazebo multi-robot simulator, version 1.8.6 Copyright (C) 2013 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
Asked by EduardoMaciel on 2013-06-27 08:15:35 UTC
The Baxter is initialized in Gazebo, but spawn_model node is finished alone and not show in the Rxgraph.
My error: [INFO] [WallTime: 1372335996.309722] [0.189000] Spawn status: SpawnModel: Successfully spawned model [spawn_model-4] process has finished cleanly log file: /home/maciel/.ros/log/cdfa700c-df24-11e2-8d02-000c291d8a96/spawn_model-4*.log
Asked by EduardoMaciel on 2013-06-27 08:16:24 UTC
After installing the (gazebo_ros_pkgs) in the directory (~ / catkin_ws / src) and install Gazebo 1.8.6 from source, I need some further configuration to run the spawn_model? My ~/.bashrc: source /opt/ros/groovy/setup.bash source /home/maciel/catkin_ws/devel/setup.bash source /usr/local/share/gazebo/setup.sh
Asked by EduardoMaciel on 2013-06-27 10:12:24 UTC
Can you modify your question, above, with the command and launch file you are using to spawn model? Also, can you include a link to your model? Thanks.
Asked by davetcoleman on 2013-06-27 19:54:00 UTC
Hi Dave, my orbit.urdf (https://gist.github.com/anonymous/5945589) and my orbit_world.launch (https://gist.github.com/anonymous/5945597). - http://postimg.org/image/v72ij8e93/ - Thanks.
Asked by EduardoMaciel on 2013-07-07 20:17:34 UTC
Hi Dave, do you have some news about the Spawn_model?
Asked by EduardoMaciel on 2013-07-12 07:15:05 UTC
