problems spawing an urdf robot with gazebo_ros
Hi there!
I'm working with a custom robot here. We are moving into ROS for controlling and interfacing with many sensors and use moveIt! as trajectory planner. So we are completely newbies here.
I had made the urdf file, which seems to work OK for rviz or movitIt wizard configuration. But despite following the tutorials from wiki the simulator wont come up with the robot.
I'm using ubuntu 12.04 with groovy. Gazebo and gazebo_ros are installed from source and seems to work loading and empty world.
What I tried to execute is the next command, where 'myrobot' is actually the robot name.
rosrun gazebo_ros spawn_model -file 'rospack find myrobot_description'/urdf/myrobot.urdf -urdf -model myrobot
The comand line output spites:
spawn_model script started
[INFO] [WallTime: 1372951949.703358] Loading model xml from file
[INFO] [WallTime: 1372951949.703925] Waiting for service /gazebo/spawn_urdf_model
And stays there forever. When hit ctrl+c appears that trace back:
File "/home/ros/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/scripts/spawn_model",
line 292, in <module>sm.callSpawnService()
line 258, in callSpawnService initial_pose, self.reference_frame, self.gazebo_namespace)
File "/home/ros/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/src/gazebo_ros/gazebo_interface.py",
line 27, in spawn_urdf_model_client rospy.wait_for_service(gazebo_namespace+'/spawn_urdf_model')
File "/opt/ros/groovy/lib/python2.7/dist-packages/rospy/impl/tcpros_service.py", line 162,
in wait_for_service raise ROSInterruptException("rospy shutdown")
rospy.exceptions.ROSInterruptException: rospy shutdown
I even tried with the tutorial for Baxter, but seems there is no URDF in the repository where it is supposed you will get it.
Any hint on how go on. I could not execute moveIt until gazebo works it seems, and after sorting all the configuration and installation troubles, here I get stuck with no clue on how keep going. So all your help will be specially appreciated!
Thanks in advance, and thanks for this great tools.
Asked by E1000i on 2013-07-04 10:48:43 UTC
Ok, was a terrible mistake from my part. I thing I was trying to spawn the model while gazebo was closed. How embarrasing...
To many hours working I guess.
So run before:
roslaunch gazebo_ros willowgarage_world.launch
and that will do the trick, as expected...
Asked by E1000i on 2013-07-08 03:35:01 UTC
Good solution. I also did not notice that the command should run while gazebo is running.
Asked by leonardo.li on 2019-08-20 10:49:54 UTC
Recently I faced the same issue and I'd like to add a small note here:
Though gazebo can be launched with just typing gazebo
in the terminal, this will not work. Because it only starts the GUI and not the services.
Whereas staring gazebo using roslaunch gazebo_ros willowgarage_world.launch
takes care of the required services.
Another way to launch is roslaunch gazebo_ros gazebo
if you do not want to include a world or a launch file.
Hope this helps!
Asked by bonag on 2018-12-21 01:47:59 UTC
