Problems to spawn an URDF model with gazebo_ros
Hi there!
I'm working with a custom robot here. We are moving into ROS for controlling and interfacing with many sensors and use moveIt! as trajectory planner. So we are completely newbies here.
I had made the urdf file, which seems to work OK for rviz or movitIt wizard configuration. But despite following the tutorials from wiki the simulator wont come up with the robot.
I'm using ubuntu 12.04 with groovy. Gazebo and gazebo_ros are installed from source and seems to work loading and empty world.
What I tried to execute is the next command, where 'myrobot' is actually the robot name.
rosrun gazebo_ros spawn_model -file 'rospack find myrobot_description'/urdf/myrobot.urdf -urdf -model myrobot
The comand line output spites:
spawn_model script started
[INFO] [WallTime: 1372951949.703358] Loading model xml from file
[INFO] [WallTime: 1372951949.703925] Waiting for service /gazebo/spawn_urdf_model
And stays there forever. When hit ctrl+c appears that trace back:
File "/home/ros/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/scripts/spawn_model",
line 292, in <module>sm.callSpawnService()
line 258, in callSpawnService initial_pose, self.reference_frame, self.gazebo_namespace)
File "/home/ros/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/src/gazebo_ros/gazebo_interface.py",
line 27, in spawn_urdf_model_client rospy.wait_for_service(gazebo_namespace+'/spawn_urdf_model')
File "/opt/ros/groovy/lib/python2.7/dist-packages/rospy/impl/tcpros_service.py", line 162,
in wait_for_service raise ROSInterruptException("rospy shutdown")
rospy.exceptions.ROSInterruptException: rospy shutdown
I even tried with the tutorial for Baxter, but seems there is no URDF in the repository where it is supposed you will get it.
Any hint on how go on. I could not execute moveIt until gazebo works it seems, and after sorting all the configuration and installation troubles, here I get stuck with no clue on how keep going. So all your help will be specially appreciated!
Thanks in advance, and thanks for this great tools.
Asked by E1000i on 2013-07-04 10:51:59 UTC
I had got the same problem while following the code from the tutorial from the construct site :2 wheeled robot using ROS
In the section 1.4, when i used the code given their.Unfortunately, It also got stuck at:
[INFO] [1569840617.521753, 0.000000]: Loading model XML from ros parameter robot_description [INFO] [1569840617.526059, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
Then I added these few lines in my launch file after:
<launch>
line.
<!-- these are the arguments you can pass this launch file, for example paused:=true --> <arg name="paused" default="false"/> <arg name="use_sim_time" default="true"/> <arg name="gui" default="true"/> <arg name="headless" default="false"/> <arg name="debug" default="false"/> <!-- We resume the logic in empty_world.launch --> <include file="$(find gazebo_ros)/launch/empty_world.launch"> <arg name="debug" value="$(arg debug)" /> <arg name="gui" value="$(arg gui)" /> <arg name="paused" value="$(arg paused)"/> <arg name="use_sim_time" value="$(arg use_sim_time)"/> <arg name="headless" value="$(arg headless)"/> <!-- arg name="world_name" value="$(find task_1)/world/tutorial_testing.world"/ --> </include>
After this my model runs in the gazebo and works fine.
Hope it may be helpful. Thanks.
Asked by pranav083 on 2019-09-29 06:04:01 UTC
Could you please explain how this made the error go away, or how you stumbled upon this?
Asked by Jaskaran Singh Sodhi on 2020-04-20 21:06:34 UTC
thank your sir
Asked by danu on 2021-01-13 11:44:34 UTC
This just worked for me, thanks!
Asked by pacman2 on 2021-01-28 19:51:36 UTC
Looks like you are trying to rin the launch file without having Gazebo open. So run:
roslaunch gazebo_launch empty_world.launch
and then in a new terminal run your launch file once gazebo has opened:
roslaunch <package_name> <launch_file_name>
Asked by gokulp01 on 2021-05-04 23:22:44 UTC
Please close this question, or its duplicate at http://answers.gazebosim.org/question/3467/problems-spawing-an-urdf-robot-with-gazebo_ros/
Asked by Ben B on 2013-07-04 12:25:09 UTC
yep, i had problems with connection ans seems that I send it twice. Sorry, i didn't realized.
Asked by E1000i on 2013-07-08 02:55:51 UTC
Thanks. Sorry I can't help with your question. I don't use the ROS version of Gazebo. For what it's worth, the standalone Gazebo seems to have fewer bugs and contains more features.
Asked by Ben B on 2013-07-08 17:41:47 UTC
