Error building plugin cvg_sim_gazebo_plugins in package tum_simulator
Hi all,
I am trying to install the tum-simulator package following the instruction shown on the ROS wiki page. When I get to building the cvg-sim-gazebo-plugins package (using rosmake) I am getting the following error: (Note that I am running ROS Groovy with Gazebo 1.5)
[ 30%] [ 38%] Building CXX object CMakeFiles/diffdriveplugin6w.dir/src/diffdriveplugin6w.cpp.o
Building CXX object CMakeFiles/hectorgazeboquadrotorsimplecontroller.dir/src/quadrotorsimplecontroller.cpp.o
/opt/ros/groovy/stacks/tumsimulator/cvgsimgazeboplugins/src/diffdriveplugin6w.cpp:38:29: fatal error: physics/physics.h: No such file or directory
compilation terminated.
/opt/ros/groovy/stacks/tumsimulator/cvgsimgazeboplugins/src/quadrotorsimplecontroller.cpp:45:29: fatal error: physics/physics.h: No such file or directory compilation terminated.
make[3]: * [CMakeFiles/diffdriveplugin6w.dir/src/diffdriveplugin6w.cpp.o] Error 1
make[3]: Leaving directory `/opt/ros/groovy/stacks/tumsimulator/cvgsimgazeboplugins/build'
make[2]: * [CMakeFiles/diffdriveplugin6w.dir/all] Error 2
make[2]: * Waiting for unfinished jobs....
make[3]: * [CMakeFiles/hectorgazeboquadrotorsimplecontroller.dir/src/quadrotorsimplecontroller.cpp.o] Error 1
make[2]: * [CMakeFiles/hectorgazeboquadrotorsimplecontroller.dir/all] Error 2
make[2]: Leaving directory `/opt/ros/groovy/stacks/tumsimulator/cvgsimgazeboplugins/build'
make[1]: * [all] Error 2
make[1]: Leaving directory `/opt/ros/groovy/stacks/tumsimulator/cvgsimgazeboplugins/build'
[ rosmake ] Output from build of package cvgsimgazebo_plugins written to:
[ rosmake ] /home/jp/.ros/rosmake/rosmakeoutput-20130718-150515/cvgsimgazeboplugins/build_output.log
[rosmake-0] Finished <<< cvgsimgazebo_plugins [FAIL] [ 5.36 seconds ]
[ rosmake ] Halting due to failure in package cvgsimgazebo_plugins.
[ rosmake ] Waiting for other threads to complete.
[ rosmake ] Results:
[ rosmake ] Built 53 packages with 1 failures.
[ rosmake ] Summary output to directory
[ rosmake ] /home/jp/.ros/rosmake/rosmake_output-20130718-150515
Could someone kindly point out what is causing the problem? From what I can understand the "physics.h" header file in "diffdriveplugin6w.cpp" does not exist. If that is the case how could I solve it?
Thanks in advance,
JP
Asked by jpcallus on 2013-07-19 13:26:50 UTC
