How to control Clearpath Husky A200 under Gazebo with ROS
I'm using ROS groovy with gazebo_ros and Clearpath Husky A200. I was able to load the A200 model in the Gazebo world and now I would like to try to control it by using my C++ code: do you think it is possible?
For example, can I use this clearpath example to virtually drive A200 robot under the Gazebo world?
int main(int argc, char *argv[]) {
/* Configure the serial port */
const char* port = (argc == 2) ? argv[1] : "/dev/ttyUSB0";
clearpath::Transport::instance().configure(port, 3 /* max retries*/);
/* Get and print some system information */
clearpath::DataPlatformInfo *platform_info = clearpath::DataPlatformInfo::getUpdate();
cout << *platform_info << endl;
delete platform_info;
clearpath::DataPowerSystem *power_info = clearpath::DataPowerSystem::getUpdate();
cout << *power_info << endl;
delete power_info;
cout << "Press enter to continue... ";
getchar();
/* Subscribe to some interesting data */
clearpath::DataSystemStatus::subscribe(1);
clearpath::DataEncoders::subscribe(5);
clearpath::DataSystemStatus * cur_status = NULL;
clearpath::DataEncoders * cur_encoders = NULL;
/* Ramp speed to 0.6m/s over 6 seconds.
* We use the 1Hz system status message for timing, so we want to begin by
* waiting for the first message, which is sent shortly after the beginning
* of the subscription */
cur_status = clearpath::DataSystemStatus::waitNext();
cout << *cur_status << endl;
delete cur_status;
for(int i=1; i<=6; ++i) {
// Set motor speed
clearpath::SetVelocity(0.1*i, 0.0, 0.5).send();
/* While waiting for the next system status message to arrive, print
* all encoder messages as they are received */
while( ! (cur_status = clearpath::DataSystemStatus::popNext()) ) {
if( (cur_encoders = clearpath::DataEncoders::popNext()) ) {
cout << *cur_encoders << endl;
delete cur_encoders;
delete cur_status;
/* Terminate subscriptions */
clearpath::DataSystemStatus::subscribe(0xffff);
clearpath::DataEncoders::subscribe(0xffff);
return 0;
Asked by marcusbarnet on 2013-07-24 12:53:04 UTC
Is there a reason you want to use your own cpp code? There is a package "clearpath_teleop", that provides all necessary nodes. It uses the "libgazebo_husky_plugin.so" provided by "husky_simulator" pacakge.
regards
psei
Asked by psei on 2013-09-05 09:45:30 UTC
