Bullet is not a registered physics engine
I am attempting to run gazebo using bullet instead of ODE. I am using Gazebo 1.8 and have Bullet 2.81 installed. Simply running "gazebo -e bullet" returns "Error [Server.cc:341] Unregistered physics engine [bullet], the default will be used instead.".
I also cannot load from the SDF file using as a tag. Is there anything else I need to do to have a "registered" Bullet physics engine?
Asked by khambuch on 2013-07-29 17:58:45 UTC
Is Bullet installed correctly? For me it looks like gazebo is trying to register Bullet but is not able to do so! You can install it from the OSRF-Repo name is libbullet-dev (Version should be 2.81).
Asked by evilBiber on 2013-07-30 01:56:01 UTC
You'll have to install Gazebo from source in order to activate Bullet support.
Asked by nkoenig on 2013-07-30 10:07:56 UTC
